<!DOCTYPE html><html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Cut Feature Collection</title> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"> <style> html,body{height:100%;width:100%;margin:0;overflow:hidden;} #map{ padding:0; } #header{ font-size: 1.1em; font-family: sans-serif; padding-left: 1em; padding-top:4px; color:#660000; } .templatePicker { border: none; } .dj_ie .infowindow .window .top .right .user .content { position: relative; } .dj_ie .simpleInfoWindow .content {position: relative;} </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://js.arcgis.com/3.6/"></script> <script> var map; require([ "esri/map", "esri/toolbars/edit", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/FeatureLayer", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/dijit/editing/Editor", "esri/dijit/editing/TemplatePicker", "esri/dijit/PopupTemplate", "esri/request", "esri/geometry/Point", "esri/graphic", "esri/config", "dojo/i18n!esri/nls/jsapi", "dojo/_base/array", "dojo/parser", "dojo/keys", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/on", "dojo/_base/array", "dojo/domReady!" ], function( Map, Edit, ArcGISTiledMapServiceLayer, FeatureLayer, SimpleMarkerSymbol, SimpleLineSymbol, Editor, TemplatePicker, PopupTemplate, esriRequest, Point, Graphic, esriConfig, jsapiBundle, arrayUtils, parser, keys, BorderContainer, ContentPane, on, array ) { var featureLayer; parser.parse(); jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start + "<br>Press <b>ALT</b> to enable snapping"; esriConfig.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); map = new Map("map", { basemap: "satellite", center: [-46.807, 32.553], zoom: 3 }); var labels = new ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer"); map.addLayer(labels); //create a feature collection var featureCollection = { "layerDefinition": null, "featureSet": { "features": [], "geometryType": "esriGeometryPolygon" } }; featureCollection.layerDefinition = { "geometryType": "esriGeometryPolygon", "objectIdField": "ObjectID", "drawingInfo" : { "renderer" : { "type" : "simple", "symbol" : { "type" : "esriSFS", "style" : "esriSFSSolid", "color" : null, "outline" : { "type" : "esriSLS", "style" : "esriSLSSolid", "color" : [ 0, 0, 0, 255 ], "width" : 1 } }, "label" : "", "description" : "" }, }, "fields": [{ "name": "ObjectID", "alias": "ObjectID", "type": "esriFieldTypeOID" }, { "name": "description", "alias": "Description", "type": "esriFieldTypeString" }, { "name": "title", "alias": "Title", "type": "esriFieldTypeString" }] }; //define a popup template var popupTemplate = new PopupTemplate({ title: "{title}", description: "{description}" }); //create a feature layer based on the feature collection featureLayer = new FeatureLayer(featureCollection, { id: 'fcLayer', infoTemplate: popupTemplate }); //associate the features with the popup on click featureLayer.on("click", function(evt) { map.infoWindow.setFeatures([evt.graphic]); }); map.on("layers-add-result", initEditor); //add the feature layer map.addLayers([featureLayer]); function initEditor(evt) { var templateLayers = arrayUtils.map(evt.layers, function(result){ return result.layer; }); var templatePicker = new TemplatePicker({ featureLayers: templateLayers, grouping: true, rows: "auto", columns: 3 }, "templateDiv"); templatePicker.startup(); var layers = arrayUtils.map(evt.layers, function(result) { return { featureLayer: result.layer }; }); var settings = { map: map, templatePicker: templatePicker, layerInfos: layers, toolbarVisible: true, createOptions: { polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ], polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON, Editor.CREATE_TOOL_CIRCLE, Editor.CREATE_TOOL_TRIANGLE, Editor.CREATE_TOOL_RECTANGLE ] }, toolbarOptions: { reshapeVisible: true, cutVisible: true, mergeVisible: true } }; var params = {settings: settings}; var myEditor = new Editor(params,'editorDiv'); //define snapping options var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CROSS, 15, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0, 0.5]), 5 ), null ); map.enableSnapping({ snapPointSymbol: symbol, tolerance: 20, snapKey: keys.ALT }); myEditor.startup(); } }); </script> </head> <body class="claro"> <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;"> <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'"> Cut Polygons </div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;"> <div id="templateDiv"></div> <div id="editorDiv"></div> </div> <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div> </div> </body> </html>
var p = new l;p.geometry = a; k.forEach(b, function (a, b) { this._settings.editor._selectionHelper.selectFeatures(, p, f.SELECTION_NEW, m.hitch(this, "_cutFeatures", a, p)) }, this)
var p = new l;p.geometry = a; var __extentBasedQuery = new l; __extentBasedQuery.geometry = esri.geometry.fromJson(p.geometry).getExtent(); k.forEach(b, function (a, b) { this._settings.editor._selectionHelper.selectFeatures(, __extentBasedQuery, f.SELECTION_NEW, m.hitch(this, "_cutFeatures", a, p)) }, this)
<!DOCTYPE html><html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Edit rivers and waterbodies</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css" /> <style> html,body{height:100%;width:100%;margin:0;overflow:hidden;} #map{ padding:0; } #header{ font-size: 1.1em; font-family: sans-serif; padding-left: 1em; padding-top:4px; color:#660000; } .templatePicker { border: none; } .dj_ie .infowindow .window .top .right .user .content { position: relative; } .dj_ie .simpleInfoWindow .content {position: relative;} </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map; require([ "esri/map", "esri/tasks/GeometryService", "esri/toolbars/edit", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/FeatureLayer", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/dijit/editing/Editor", "esri/dijit/editing/TemplatePicker", "esri/config", "dojo/i18n!esri/nls/jsapi", "dojo/_base/array", "dojo/parser", "dojo/keys", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, GeometryService, Edit, ArcGISTiledMapServiceLayer, FeatureLayer, SimpleMarkerSymbol, SimpleLineSymbol, Editor, TemplatePicker, esriConfig, jsapiBundle, arrayUtils, parser, keys ) { parser.parse(); // snapping is enabled for this sample - change the tooltip to reflect this jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start + "<br>Press <b>ALT</b> to enable snapping"; // refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/en/javascript/jshelp/ags_proxy.html esriConfig.defaults.io.proxyUrl = "/proxy"; //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications. esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); map = new Map("map", { basemap: "satellite", center: [-96.541, 38.351], zoom: 14, slider: false }); map.on("layers-add-result", initEditor); //add boundaries and place names var labels = new ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer"); map.addLayer(labels); var rivers = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer/1",{ mode: FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); var waterbodies = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer/0",{ mode: FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); map.addLayers([waterbodies,rivers]); function initEditor(evt) { var templateLayers = arrayUtils.map(evt.layers, function(result){ return result.layer; }); var templatePicker = new TemplatePicker({ featureLayers: templateLayers, grouping: true, rows: "auto", columns: 3 }, "templateDiv"); templatePicker.startup(); var layers = arrayUtils.map(evt.layers, function(result) { return { featureLayer: result.layer }; }); var settings = { map: map, templatePicker: templatePicker, layerInfos: layers, toolbarVisible: true, createOptions: { polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ], polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON, Editor.CREATE_TOOL_CIRCLE, Editor.CREATE_TOOL_TRIANGLE, Editor.CREATE_TOOL_RECTANGLE ] }, toolbarOptions: { reshapeVisible: true, cutVisible: true } }; var params = {settings: settings}; var myEditor = new Editor(params,'editorDiv'); //define snapping options var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CROSS, 15, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0, 0.5]), 5 ), null ); map.enableSnapping({ snapPointSymbol: symbol, tolerance: 20, snapKey: keys.ALT }); myEditor.startup(); } }); </script> </head> <body class="claro"> <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;"> <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'"> Edit Hydrography </div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;"> <div id="templateDiv"></div> <div id="editorDiv"></div> </div> <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div> </div> </body> </html>
Questions: how long are you waiting for the cut operation to complete?do you see a request to the cut endpoint on tasks.arcgisonline.com?do you have a proxy set up when running this sample locally?Regarding using the cut operation with a feature collection and why your fix works: when using a feature collection, we can only query by extents and not arbitrary lines/polygons. I'll take this use case back to the team and see what we want to do. At the very least, we should log something to the console saying the attempted query isn't supported when using a feature layer from a feature collection.
When I noticed the lag, that told me that the cut tool didn't work. I cannot recall if I tried my "bug fix" with a feature layer. Maybe it works?
Blame Kelly for opening my eyes to feature collections. They are amazingly useful!
Agreed, feature layers from feature collections are a great thing but they are limiting when your app requires editing and/or advanced querying capabilities.
Is there information in the documentation about what makes feature layers from feature collections so great?
You get a feature layer w/o having to publish an arcgis server map or feature service. That may or may not appeal to you...the main sample in the SDK that does this takes data from a 3rd party (flickr) and creates a feature layer from it: https://developers.arcgis.com/en/javascript/jssamples/fl_featureCollection.html
how long are you waiting for the cut operation to complete?For the ESRI samples, right now it takes about 2-3 seconds for the cut process to complete. It takes about a second to start displaying any change.do you see a request to the cut endpoint on tasks.arcgisonline.com?I'm guessing this is in reference to my personal project. No. I use my own GeometryService from my own ArcGIS Server.do you have a proxy set up when running this sample locally?The sample, no. Proxy within my personal project for layers, yes. Even the GeometryService is proxied. Interestingly, all of my cut requests are instantaneous. No lag.
Thanks. Since the sample in question doesn't include cut, you need to modify it and run it locally. When you do this, you have to have a proxy configured on the web server where you run the sample if you want to successfully use services on tasks.arcgisonline.com and sampleserver3.I don't know where this leaves us...there are a number of moving parts here but I'll try to summarize:the editor with cutVisible: true works as designed but requires a proxy on the web server where your app runsthe editor's cut tool is not supported with feature layers from feature collections and we'll do a better job of indicating this in the docs as well via a message logged to the browser's console when you try to do this
