Is there a way to change the zoom levels. so that one can zoom in beyond 60ft/20 m using an ESRI base map. I have tried in edit to change zoom scales but it seems by default zoom in beyond 60 ft is not available.
Hi George,
The ESRI Basemaps & Google Maps all have the same 20 common web map zoom levels because those are the scales that tile creation was done at. If you were to zoom in closer, there is no tile layer associated with that view. You can create your own basemap tiles and set their zoom levels at cache creation if you wanted to make something custom for your needs.
Cheers,
Todd
I don't think it is possible. Those basemaps are cached at those levels. If you did zoom in, the basemap would become pixelated. You can add the basemaps to ArcMap and zoom in to a larger scale, but if you do you will see the degradation of the basemap's resolution.
Thanks Todd, I guess I will have to live with the current zoom levels, I would ideally like using the imagery layer to zoom in to street level basically as far as I could. But I guess this level of zoom will have to do.
George,
I add LODs to my WAB App that allow for zooming in beyond the esri basemap lowest scale and to prevent any issue that Jeff mentioned I just set the maxScale of the esri basemap to turn it off. In WAB 1.1 you can define extra LODs in the maps UI dialog.
Thanks Robert, how do you change the maps UI dialogue?
in WAB on the map tab you will find the "Customize Visible Scales" (which means LODs).
Yes that's where I changed them, so if I wanted to add the ability to zoom in to 10 feet using aerial imagery would by format be 10 on LOD UI, I think my format is incorrect.
Normally I would take the last LOD the map supports and find it's scale and divide that by 2, add that scale and then repeat that as many time as I need to to get down to the desired scale. I don't think you can just enter 10 and hit the plus button.
According to the dev summit all basemaps (not sure on imagery) will soon be vector so you can zoom into any level. This is because of the js 4.0 api will allow 3d maps and now you will get to see basemaps from an angle not just from the top.
-Stan
