Hi all,I have had similar issues to what I see described in the previous posts and I believe it may be a bug which is triggered the first time you output to UTM using the "Convert file(s)..." feature. When subsequent batch conversions are performed the Grid InQuest software appears to remember the previous output coordinate setting being UTM and uses this over the output coordinate system manually chosen.I've found that deleting a few registry keys can fix this issue.In Registry Editor (Start > Run > regedit.exe) navigate to HKEY_CURRENT_USER\Software\Quest\. When I have had this issue I have deleted the entire contents under the Quest key, however it is likely that deleting the values "Destination Format", "Destination Zone", "Format", "Source Format" and "Source Zone" under HKEY_CURRENT_USER\Software\Quest\GridInQuest\Preferences\ will be sufficient.Hope this helps!Ben
Melita.Thanks for your help on this. The converted cooprdinates you've shown are exaclty where I want them. You've confirmed that I've been using the tool correctly. However here is my set of results:361780.838,6258878.527,-53.716,Newlyn361816.476,6258836.520,-52.715,Newlyn361825.238,6258884.503,-51.715,Newlyn361847.831,6258883.766,-50.715,Newlyn361852.243,6258924.466,-49.715,Newlyn361870.605,6258888.593,-48.715,Newlyn361880.269,6258869.713,-47.715,Newlyn361903.224,6258848.542,-46.715,Newlyn361928.594,6258806.872,-45.714,Newlyn362398.663,6258466.684,-44.710,Newlyn362455.654,6258258.761,-43.710,Newlyn362696.934,6258406.878,-42.708,Newlyn362674.885,6258392.741,-41.708,Newlyn362700.626,6258362.202,-40.708,Newlyn362710.050,6258367.466,-39.708,NewlynI am definitly modifying the output to OSGB36 when running through the wizard. Time to email Grid inQuest I think!
Melita.I can transform individual coords via Grid inQuest's GUI; in fact I did this manually for a small set of coords, appended the results to my original spreadsheet, created XY feature from this set, added to ArcMap and they plot exactly where I want them to. It's the conversion of Batch Coords that doesn't work for me.Set attached. Couldn't attach a .csv here, so added an .xlsThanks.
Hi.I'm hoping someone will entertain this query and apologies if it's been done to death.I have a set of GPS coordinates - points near the coastline. I want to tranform them to British National Grid (BNG) so I can display against some raster mapping of land.1. My initial solution was to take the spreadsheet of coords, convert from degrees/decimal minutes to decimal degrees. Then use the Convert (files) function of Grid inQuest to transform from ETRS89 to BNG. Then create XY data.However, individual conversions work in Grid inQuest but every time I use the Convert (files) my results never produce a list in BNG. 2. I'm also attempting to use the Project function from Toolbox, however the Geographic Transformation option does not provide the tranformation I want, ETRS89 to BNG/OSGB36.Thanks.
