After updating to Pro 2.3 and cloning the default env to two different envs I get this error when I start Spyder:
Not sure what's up with that; anybody else getting it?
Dan Patterson
Joe....
seem like you are trying to run spyder.exe directly...
create a shortcut as suggested in my many blogs
Target
C:\arc_pro\bin\Python\envs\arcgispro-py3\pythonw.exe "C:\arc_pro\bin\Python\envs\arcgispro-py3\Scripts\spyder-script.py"
start in
This happens to be for where it is installed in the default ArcGISpro-py3 environment...
Just change the bold-faced text above with your paths.
Guilty as charged.... But, now I'm getting the original error with a different presentation:
Checking git hub now.....
eta:
In a Python command window type
conda update spyder
I think the problem stemmed from installing the spyder-kernal package that is bundled with Pro 2.3: conda tossed:
Thanks Dan!
I am using 3.3.2 with spyder-kernels 0.3.0 There was a huge leap in spyder-kernels to 1.0.? when I ran
conda update spyder-kernels --dry-run
I suspect it has to do with spyder 4 being released some time this quarter.
I normally update the main package (spyder) and leave other stuff alone unless I check it out on GitHub first to see if there are peripheral issues.
My Spyder is now 3.3.2...
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
