NOTE: as of Version 10.3, the SpatialReference object contains the "latitudeOfOrigin" property, and the trick below is unncessary.
Hi Tim,
It looks like a property which should be included in the SpatialReference object, but I don't see it either. For a quick and dirty hack, you can pull the relevant string out of the exportToString() results:
import arcpy import re # a projection with a latitude of origin property proj = 'NAD 1983 Contiguous USA Albers' sr = arcpy.SpatialReference(proj) lat_of_origin_regex = "Latitude_Of_Origin',(\d+\.?\d*)]" match = re.search(lat_of_origin_regex, sr.exportToString()) if match: lat_of_origin = float(match.groups()[0]) print "{0} has latitude of origin {1}".format(proj, lat_of_origin) else: print "no latitude of origin detected."
Set up your own spatial reference object in the code above, and you should be able to use the lat_of_origin variable to get what you need.
cheers, Shaun
Note there are no more system-based .prj file in v10.1 anymore (!!!!) But you can manufacture one via the SR's exportToString() method and then write it to a file.
Seems like a bug to not have that property available...
thanks for this answer!
Note: with 10.3 you'll need to use lat_of_origin_regex = "latitude_of_origin',(\d+\.?\d*)" with lowercases
also, you can also use the factoryCode in the arcpy.SpatialReference()
As of ArcGIS 10.3, this issue is fixed and you can directly use the latitudeOfOrigin property:
>>> sr = arcpy.SpatialReference("NAD 1983 Contiguous USA Albers")
>>> sr.latitudeOfOrigin
23.0
I'd use that over the solution I'd originally posted above for any newer release.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
