Hi, Is there any way to add more than 100 maps sections in map Journal?
oops sorry. We don't have that FAQ for Map Journal yet but it's same pattern, the configuration to change is app/config.js
Hi, yes by using the downloadable version, details on GitHub.
Hi Gregory,
I am referring to the Map Journal and the link you provided describes about Map Tour
Hey Gregory,
I am new to Story Maps. I have created two story maps for my County representing tourist sites. I am having trouble with customization and could really use some help. Would you mind look at my current story map and giving me some suggestions? I am not a programmer but I understand a little bit of HTML which I have used to customize the titles for purposes of branding. These story maps are really important because they will be published to the public and I need to make sure they are perfect.
Also, I am in need of adding more icon colors to represent 11 different categories and also to extend the amount of points that I can add. I have approximately 194 tourist points and this story map template will only allow 100.
Thank you in advance for any help or advice.
Here is the link to my current story map:
http://marioncountyfl.maps.arcgis.com/apps/MapTour/?appid=6f745d868e2843058fb5f10fcbdfc18f
~ Amanda
Hey Amanda,
Your Tour is looking good, I like the colors.
There is four FAQ entries that should answer all your questions:
- Can I use more than 99 points?
- The downloadable version
- Can I use the builder with the downloadable?
- Can I customize the map icons?
Doing 11 categories for 194 points may be a lot of icon creation work.
Let us know if you have any questions.
Have you also considered Shortlist?
I have completed the following steps
var configOptions = {
// Enter an application ID created through the Story Map Journal Builder
appid: "",
When I open the application from my web server, it does not open with edit option.
I have reached to the GitHub and it says:
“Yes, when the template is configured with an application ID, adding the URL parameter 'edit' will open the builder. You will be prompted for user authentication through the Identity Manager.”
I am in the learning phase, any suggestion for the customization to add more than 100 section on map journal will be appreciated.
Mahesh
Thank you for you reply and thank you for the compliment! Although, I feel like maybe the Map Tour I created doesn't quite suite the amount of data or how it needs to be represented.
I am interested int he Shortlist style and I am reading through the tutorials on how to create the short list. Question... could I possibly use my existing Web Map? It says you have to create one in your ArcGIS online in order to load all your shortlist layers.
Also, once, I load all my features into the Web Map (which I was planning on making a layer for each category - ie.- Activities, Arts & Culture, Boating & Fishing, Equine, etc.), how do I go about creating the custom icons for each category?
I am sure I will be able to figure it out eventually, but any advice you can offer will be greatly appreciated!
Thank you.
Amanda
