Hi, Is there any way to add more than 100 maps sections in map Journal?
oops sorry. We don't have that FAQ for Map Journal yet but it's same pattern, the configuration to change is app/config.js
Hi, yes by using the downloadable version, details on GitHub.
Hi Gregory,
I am referring to the Map Journal and the link you provided describes about Map Tour
Hey Gregory,
I am new to Story Maps. I have created two story maps for my County representing tourist sites. I am having trouble with customization and could really use some help. Would you mind look at my current story map and giving me some suggestions? I am not a programmer but I understand a little bit of HTML which I have used to customize the titles for purposes of branding. These story maps are really important because they will be published to the public and I need to make sure they are perfect.
Also, I am in need of adding more icon colors to represent 11 different categories and also to extend the amount of points that I can add. I have approximately 194 tourist points and this story map template will only allow 100.
Thank you in advance for any help or advice.
Here is the link to my current story map:
http://marioncountyfl.maps.arcgis.com/apps/MapTour/?appid=6f745d868e2843058fb5f10fcbdfc18f
~ Amanda
I have completed the following steps
var configOptions = {
// Enter an application ID created through the Story Map Journal Builder
appid: "",
When I open the application from my web server, it does not open with edit option.
I have reached to the GitHub and it says:
“Yes, when the template is configured with an application ID, adding the URL parameter 'edit' will open the builder. You will be prompted for user authentication through the Identity Manager.”
I am in the learning phase, any suggestion for the customization to add more than 100 section on map journal will be appreciated.
Mahesh
You must be almost there!
The edit button won't be present, you have to specify to open yourself through the application URL.
To open the builder, your URL have to end by '?edit', something like http://myserver/MapTour/index.html?edit
