“Diagram properties” for models created in ArcGIS Pro,
I couldn’t figure out how to set the “Diagram properties” for models created in ArcGIS Pro,
Thank you
Best
Jamal
Ah - okay - yes, you can do that with AGP 2.3. In my before picture is a model with the default view of left to right. In the ModelBuilder-Diagram contextual tab upper right of the ribbon (blue), I click on the Flip Orientation in the Orientation Group. The result is my second picture. Top to bottom!
Links
https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/basics/create-a-model-tool.htm
and
https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/modelbuilder/model-properties.htm
but your model has no parameters, so there is nothing to change as in your previous post
For example, how to choose the “orientation” to be “top to bottom” for models created in ArcGIS Pro?
I would have to look further in those links that I sent you.
I need to check if the “diagram properties” is implemented in 2.0.1
don't see anything that specific Jamal, but I rarely use it... just what is in this link...
http://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/modelbuilder/diagram-and-display-properties.htm
curtvprice uses ModelBuilder way more than I, so perhaps he has toyed with the Pro offerings in 2.0 or 2.1
For me, I would love to have this option as I prefer to have “top to bottom” model instead of “left to right”. Not sure why we should lose features\capacity as we move from version to another.
I've never used this feature in ArcMap. It sure doesn't look available in Pro to me:
Diagram and Display Properties—ArcGIS Pro | ArcGIS Desktop
I think that the only way out for this is that the developers of ArcGIS Pro need to have deep look on all options\settings\features that are already available in ArcGIS and try not to miss any of them.
Jamal... you should close your threads even if the answers aren't to your liking. You can either choose an answer (like it or not), mark as assumed answered or convert to a discussion)
Dan,
I have already liked all answers provided.
I will mark it assumed answered then
In my BETA copy of Pro 2.1, you can add a vertex to a connector line and reshape the view of the model. Or select the input data and move it an offset location - Pro will add the "jog" for you. Further, you can position your Input Data-GP tools-intermediate data in any orientation you wish. Then select all the graphics and click the Lock Element button on the View Group of the ModelBuilder tab. Then when you click Auto Layout, it doesn't reorient left to right at all.
Thanks Robert for the input.
I applied the “lock element” and “auto layout” technique and it appears that it doesn’t form neither a solution not a workaround. It is not a replacement for the features\tools that are available in ArcMap.
Granted, not a replacement for existing functionality. Hopeful this behavior gets added to the next release of Pro.
This appears not to be fixed even in 2.3. Tt would be nice if all functionalities\behavior that are used to be in ArcMap to be incorporated in the 2.3
