Ryan,
Did you ever find a solution to your question? Which option did you choose?
What's wrong with Spatial Join?
Darren,
In my workflow option 3 might be a better an option. Spatial Join produces a whole new feature class as an output, instead of transferring an attribute from a selected polygon to the point features within the selected polygon. Thoughts?
Oh I see. It probably depends somewhat on the size of the datasets. Suppose there are 1000 points. You could do 1000 individual selections/field calculations, or 1 spatial join (to an in-memory feature class if you don't want to keep it) then 1 join then 1 field calculation. I'm guessing the second option is faster, but haven't tested.
I know I am not an efficient python scripter, so bear with me. I have attempted to script it with spatial join. The goal is to calculate the zone of a concern for only the ones that the zone field is null. Both feature classes are in an enterprise environment (the concerns and the zones). Here is what I have so far from testing on a file geodatabase. I am not sure it is joining properly and the field calculator dies. Any suggestions?
<SPAN class="comment token"># import modules</SPAN> <SPAN class="keyword token">import</SPAN> arcpy <SPAN class="comment token"># Set workspaces</SPAN> workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\ESRITest\GeoReportingSystem\Testing9116\Testing9116.gdb'</SPAN> outWorkspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\ESRITest\GeoReportingSystem\Testing9116\Scratch.gdb'</SPAN> targetFeatures <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\ESRITest\GeoReportingSystem\Testing9116\Testing9116.gdb\GeoReporting'</SPAN> joinFeatures <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\ESRITest\GeoReportingSystem\Testing9116\Testing9116.gdb\GRSAldermanic'</SPAN> outfc <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\ESRITest\GeoReportingSystem\Testing9116\Scratch.gdb\AldermanicSJ'</SPAN> fieldmappings <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>FieldMappings<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> fieldmappings<SPAN class="punctuation token">.</SPAN>addTable<SPAN class="punctuation token">(</SPAN>targetFeatures<SPAN class="punctuation token">)</SPAN> fieldmappings<SPAN class="punctuation token">.</SPAN>addTable<SPAN class="punctuation token">(</SPAN>joinFeatures<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script</SPAN> <SPAN class="comment token"># The following inputs are layers or table views: "GeoReporting Features", "GRSAldermanic"</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>SpatialJoin_analysis<SPAN class="punctuation token">(</SPAN>target_features<SPAN class="operator token">=</SPAN>targetFeatures<SPAN class="punctuation token">,</SPAN> join_features<SPAN class="operator token">=</SPAN>joinFeatures<SPAN class="punctuation token">,</SPAN> out_feature_class<SPAN class="operator token">=</SPAN>outfc<SPAN class="punctuation token">,</SPAN> join_operation<SPAN class="operator token">=</SPAN><SPAN class="string token">"JOIN_ONE_TO_ONE"</SPAN><SPAN class="punctuation token">,</SPAN> join_type<SPAN class="operator token">=</SPAN><SPAN class="string token">"KEEP_COMMON"</SPAN><SPAN class="punctuation token">,</SPAN> field_mapping<SPAN class="operator token">=</SPAN>fieldmappings<SPAN class="punctuation token">,</SPAN> match_option<SPAN class="operator token">=</SPAN><SPAN class="string token">"INTERSECT"</SPAN><SPAN class="punctuation token">,</SPAN> search_radius<SPAN class="operator token">=</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> distance_field_name<SPAN class="operator token">=</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Done with Spatial Join"</SPAN> <SPAN class="comment token"># Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script</SPAN> <SPAN class="comment token"># The following inputs are layers or table views: "AldermanicSJ"</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>DeleteField_management<SPAN class="punctuation token">(</SPAN>in_table<SPAN class="operator token">=</SPAN>outfc<SPAN class="punctuation token">,</SPAN> drop_field<SPAN class="operator token">=</SPAN><SPAN class="string token">"SpecificConcern;DescriptionOfConcern;ReportingEmail;DateClosed;ConcernStatus;PriorityLevel;PrimaryDepartment;PrimaryContact;PrimaryInformation;DeptLogging;ReportingMethod;FollowUpRequest;FollowUpContactInfo;AldermanicDistrict;ApproriateYN;NUMVOTES;DaysToClose;Match_Addr;Loc_Name;created_user;created_date;last_edited_user;last_edited_date;Address;Visibility;Report_ID;DISTRICTID"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Done with Deleting Fields"</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>outfc<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"outfc_view"</SPAN><SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>targetFeatures<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"GRE_view"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># arcpy.MakeFeatureLayer_management(targetFeatures, "GRE_view")</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddJoin_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"GRE_view"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ConcernID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"outfc_view"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ConcernID"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Joined Up Sir"</SPAN> fieldName1 <SPAN class="operator token">=</SPAN> <SPAN class="string token">"GRE_view.AldermanicDistrict"</SPAN> fieldName2 <SPAN class="operator token">=</SPAN> <SPAN class="string token">"!outfc_view.NAME!"</SPAN> <SPAN class="comment token"># Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script</SPAN> <SPAN class="comment token"># The following inputs are layers or table views: "GeoReporting Features"</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>in_table<SPAN class="operator token">=</SPAN>targetFeatures<SPAN class="punctuation token">,</SPAN> field<SPAN class="operator token">=</SPAN>fieldName1<SPAN class="punctuation token">,</SPAN> expression<SPAN class="operator token">=</SPAN>fieldName2<SPAN class="punctuation token">,</SPAN> expression_type<SPAN class="operator token">=</SPAN><SPAN class="string token">"PYTHON"</SPAN><SPAN class="punctuation token">,</SPAN> code_block<SPAN class="operator token">=</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Field Calculation Done"</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>RemoveJoin_management<SPAN class="punctuation token">(</SPAN>in_layer_or_view<SPAN class="operator token">=</SPAN>targetFeatures<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Removed Join"</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>DeleteFeatures_management<SPAN class="punctuation token">(</SPAN>outfc<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Spatial Join feature class deleted"</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
