Before I updated my Web AppBuilder to 2.6, I was able to configure the Query Widget so that the user had a choice of using the spatial filters available or the sql expression I created. Now I am unable to use the sql expression (the "Apply" button is grayed out). I can only use the spatial filter. I would like to make both options available. Any idea on how to do that? Thanks!
Fini,
I am not sure why this changed but to fix it just make this code change:
In the Query widgets folder find TaskSetting.js and update the _updateExecuteButtonStatus function to:
(line 2 && changed to ||).
_updateExecuteButtonStatus<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> isValid <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">_isValidWhereToExecute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">||</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">_isValidGeometryToExecute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>isValid<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>btnExecute<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'disabled'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>btnExecute<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'disabled'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">return</SPAN> isValid<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
