Can someone shows me how to modify this sample Show find task results in a DataGrid | ArcGIS API for JavaScript to query task?
Thanks.
May Jeff,
Here is a fiddle with the needed corrections. You need to double check your field names for your queries and make sure you are using the alias for your requires.
JSFiddle Link
Here is the JSFiddle
Edit fiddle - JSFiddle
Thank you very much Robert. That's what I need.
Hi Robert,
i am trying to implement the same with some drill down functionality. when i zoom to village level the point features should be highlighted, displaying their attributes in a table as in this example.
i am getting the values from the layers but not filling in the table.
where am i going wrong, here is the code
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>AP Housing Application</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.13/dojox/grid/resources/Grid.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.13/dojox/grid/resources/claroGrid.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
<style type="text/css">body,html,#main{margin:0;padding:0;height:100%;width:100%;}</style>
<script src="http://js.arcgis.com/3.13/"></script>
<script>dojoConfig = { parseOnLoad: true };</script>
<style>
html, body, #map {
padding: 0;
margin: 0;
height: 100%;
/* Change color of icons to match bar chart and selection symbol */
.esriPopup.dark div.titleButton,
.esriPopup.dark div.titlePane .title,
.esriPopup.dark div.actionsPane .action {
color: #000000;
font-weight: bold;
/* Additional customizations */
.esriPopup.dark .esriPopupWrapper {
border: none;
.esriPopup .contentPane {
text-align: left;
.esriViewPopup .gallery {
margin: 0 auto;
.title {
padding:10px;
background:#fafafa;
.title .logo img {
float:left;
margin-right:10px;
.title .logo h1{
color: #C9584F;
padding: 0px;
font-size: 30px;
font-family:Arial, Helvetica, sans-serif;
margin:0px;
.title .logo h1>span{
color: #111;
font-size: 20px;
.title .cm {
float:right;
text-align:center;
font-size:15px;
.title .cm h2{
</style>
<script>
var map;
var veTileLayer;
var findTask, findParams;
var center, zoom;
var grid, store, store3;
var county;
var resizeTimer;
require([
"esri/map", "esri/tasks/query", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters", "dojo/_base/array","dojo/DeferredList",
"dijit/form/ComboBox", "dojo/data/ItemFileReadStore","dojo/store/Memory",
"esri/virtualearth/VETiledLayer", "dijit/form/Button",
"esri/tasks/FindTask",
"esri/tasks/FindParameters",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"dijit/registry",
"dojo/_base/connect",
"dojox/grid/DataGrid",
"esri/dijit/Popup", "esri/dijit/PopupTemplate",
"esri/layers/FeatureLayer",
"esri/symbols/SimpleFillSymbol", "esri/Color",
"dojo/dom-class", "dojo/dom-construct",
"dojox/charting/Chart", "dojox/charting/themes/Dollar",
"dojo/on", "dojo/domReady!"],
function(Map, query, parser, BorderContainer, ContentPane,
IdentifyTask, IdentifyParameters,arrayUtils,DeferredList,
ComboBox, ItemFileReadStore, Memory,
VETiledLayer, Button,
FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, registry, connect, DataGrid,
Popup, PopupTemplate,
FeatureLayer,
SimpleFillSymbol, Color,
domClass, domConstruct,
Chart, theme,
on, Scalebar) {
parser.parse();
/* map = new Map("map");
function init() {
//Creates the Virtual Earth layer to add to the map
//Example for adding a Bing Maps key
// bingMapsKey: "1B2C3OlkbxWHYa1b2c3qkPrO_Ou3nRrGtSa_5Op-xvPNya1b2c3",
veTileLayer = new esri.virtualearth.VETiledLayer({
bingMapsKey:'Ame5R45lEOTdPXxlhxuAXN2sDT8vyEJcgXGeZpPOPHBLbg2XqkPMaL5OJHp0OlV0',
mapStyle: esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL
map.addLayer(veTileLayer);
infoWindow: popup
dojo.ready(init);*/
var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
var popup = new Popup({
fillSymbol: fill,
titleInBody: false
}, domConstruct.create("div"));
//Add the dark theme which is customized further in the <style> tag at the top of this page
domClass.add(popup.domNode, "dark");
map = new Map("map", {
basemap: "satellite",
/*center: [-122.45, 37.75], // longitude, latitude */
center : [79.2, 18.10],
zoom: 6,
var template = new PopupTemplate({
title: "AP HOUSING APPLICANTS <BR>",
description: "<BR> BENEFICIARY ID: {ben_id} <br> <br>BENEFICIARY NAME: {ben_name} <br><br>FATHER'S NAME: {father_nam}<br><br>AADHAR ID : {uid} <br><br> SCHEME NAME: {scheme_nam} <br><br>LATITUDE: {lat} <br><br> LONGITUDE: {lon} <br>",
var featureLayer = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer/0",{
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["*"],
infoTemplate: template
veTileLayer = new VETiledLayer({
map.addLayer(featureLayer);
var polygonQuery = null;
var polygonQueryTask = null;
var polygonQuery1 = null;
var polygonQueryTask1 = null;
var polygonQuery2 = null;
var polygonQueryTask2 = null;
var polygonQuery3 = null;
var polygonQueryTask3 = null;
// RIYAS: Wait till map is loaded before firing query, needed for getting map spatial reference
map.on("load", function () {
var queryTask = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer/1");
// var queryTask1 = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/pattasample/MapServer/2");
//Define query parameters
var query = new esri.tasks.Query();
query.outFields = ["dname"];
query.returnGeometry = true;
query.outSpatialReference = map.spatialReference; // RIYAS: Set query to return shape in map's spatial reference
query.where = "dname <> ''"
queryTask.execute(query,populateList);
/*var query1 = new esri.tasks.Query();
query1.outFields = ["dname", "mname"];
query1.returnGeometry = true;
query1.outSpatialReference = map.spatialReference; // RIYAS: Set query to return shape in map's spatial reference
query1.where = "mname<> ''"
queryTask1.execute(query1,populateList1);*/
// RIYAS: Setup query to behave as identify
polygonQueryTask = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer/1");
polygonQuery = new esri.tasks.Query();
polygonQuery.returnGeometry = true;
polygonQuery.outFields = ["dname"];
polygonQuery.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
polygonQuery.outSpatialReference = map.spatialReference;
polygonQueryTask1 = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer/2");
polygonQuery1 = new esri.tasks.Query();
polygonQuery1.returnGeometry = true;
polygonQuery1.outFields = ["dname", "mname"];
polygonQuery1.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
polygonQuery1.outSpatialReference = map.spatialReference;
polygonQueryTask2 = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer/3");
polygonQuery2 = new esri.tasks.Query();
polygonQuery2.returnGeometry = true;
polygonQuery2.outFields = ["dname", "mname", "vname"];
polygonQuery2.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
polygonQuery2.outSpatialReference = map.spatialReference;
polygonQueryTask3 = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer/0");
polygonQuery3 = new esri.tasks.Query();
polygonQuery3.returnGeometry = true;
polygonQuery3.outFields = ["*"];
polygonQuery3.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
polygonQuery3.outSpatialReference = map.spatialReference;
var infoTemplate = new esri.InfoTemplate("District: ${dname}", "District : ${dname}<br/>");
var infoTemplate1 = new esri.InfoTemplate("DISTRICT: ${dname}", "District : ${dname}<br/> Mandal : ${mname}<br/> ");
var infoTemplate2 = new esri.InfoTemplate("DISTRICT: ${dname}", "District : ${dname}<br/> Mandal : ${mname}<br/> Village : ${vname}<br/>");
var infoTemplate3 = new esri.InfoTemplate("DISTRICT: ${ben_id}", "BENEFICIARY : ${ben_id}<br/>BENEFICIARY name : ${ben_name}<br/>fathers name : ${father_nam}<br/> AADHAR : ${uid}<br/> scheme name : ${scheme_nam}<br/> District : ${dname}<br/> Mandal : ${mname}<br/> Village : ${vname}<br/>");
var infoTemplates = [infoTemplate, infoTemplate1,infoTemplate2,infoTemplate3];
//map.on("click", executeIdentifyTask);
// RIYAS: Execute query to behave as identify
function executeIdentifyTask (where, pnt) {
//polygonQuery.where = event.mapPoint;
//polygonQuery1.where = event.mapPoint;
polygonQuery.where = where;
polygonQuery1.where = where;
polygonQuery2.where = where;
polygonQuery3.where = where;
var deferred = polygonQueryTask
.execute(polygonQuery);
var deferred1 = polygonQueryTask1
.execute(polygonQuery1);
var deferred2 = polygonQueryTask2
.execute(polygonQuery2);
var deferred3 = polygonQueryTask3
.execute(polygonQuery3);
// InfoWindow expects an array of features from each deferred
// object that you pass. If the response from the task execution
// above is not an array of features, then you need to add a callback
// like the one above to post-process the response and return an
// array of features.
var defList = new DeferredList([deferred, deferred1, deferred2, deferred3]).then(function (results){
var features = [];
arrayUtils.forEach(results,function(result, idx){
if (result[0] === true){
features = features.concat(arrayUtils.map(result[1].features, function (feature) {
feature.setInfoTemplate(infoTemplates[idx]);
return feature;
map.infoWindow.setFeatures(features);
map.infoWindow.show(pnt);
//var initialExtent = new esri.geometry.Extent(-85.915,38.105,-85.52,38.33,
// new esri.SpatialReference({wkid:4326}) );
// map = new esri.Map("map", {extent:initialExtent});
//Create tiled and dynamic map services and add to the map - for the dynamic service set the transparency
//and provide an id so we can access it later
// map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"));
map.addLayer(new esri.layers.ArcGISDynamicMapServiceLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer",
{"opacity":1,"id":"dynamic"}));
function populateList(results) {
//initialize InfoTemplate
//create symbol for selected features
symbol = new esri.symbol.SimpleMarkerSymbol();
symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
symbol.setSize(0.1);
symbol.setColor(new dojo.Color([255, 255, 0, 0.5]));
//Populate the dropdown list box with unique values
// var county;
var values = [];
var testVals={};
//Add option to display all zoning types to the dropdown list
values.push({name:""})
var features = results.features;
dojo.forEach (features, function(feature) {
county = feature.attributes.dname;
if (!testVals[county]) {
testVals[county] = true;
values.push({name:county,shape:feature.geometry,centroid: feature.geometry.type === "point" ? feature.geometry : feature.geometry.getCentroid() }); // RIYAS: set shape to list store
var dataItems = {
identifier: 'name',
label: 'name',
items: values
var store = new dojo.store.Memory({data:dataItems});
dijit.byId("mySelect").store = store;
//remove all graphics on the maps graphics layer
map.graphics.clear();
//Performance enhancer - assign featureSet array to a single variable.
var resultFeatures = results.features;
//Loop through each feature returned
for (var i = 0, il = resultFeatures.length; i < il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic = resultFeatures;
graphic.setSymbol(symbol);
//Set the infoTemplate.
graphic.setInfoTemplate(infoTemplate);
//Add graphic to the map graphics layer.
map.graphics.add(graphic);
// This takes the graphics array you get back from your query and
// gets the overall extent for them. Make sure return geometry is set to
// true in your query.
var extent = esri.graphicsExtent(results.features);
// Use that to set the extent, 1.5 is something I use in my app, but play with
// it to find a setting you like, setting the second parameter to true will get you an extend
// that is at the closest level of your cached service.
map.setExtent(extent.expand(1.0), true);
// this replaces your applyLayerDef() function
dijit.byId("mySelect").on("change", function () {
//Filter the layer to display only the selected zoning types
var county = dijit.byId("mySelect").value;
var centroid = dijit.byId("mySelect").item.centroid;
if (county !== 'ALL') {
var layerDefs = [];
layerDefs[2] = "dname = " + "'" + county + "'";
layerDefs.visibleLayers = [2];
map.setExtent(dijit.byId("mySelect").item.shape.getExtent(infoTemplate).expand(1.7)); // RIYAS: Get shape from list store and zoom to its extent
executeIdentifyTask("dname = '" + county + "'", centroid);
// RIYAS: cannot set layer defintion for dynamic map service.
//map.getLayer("dynamic").setLayerDefinitions(layerDefs);
else {
//map.getLayer("dynamic").setDefaultLayerDefinitions();
var queryTask1 = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer/2");
query1.where = "mname<> '' and dname='"+dijit.byId("mySelect").value+"'"
function populateList1(results1) {
/* alert(dijit.byId("mySelect").value)
symbol1 = new esri.symbol.SimpleMarkerSymbol();
symbol1.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
symbol1.setSize(0.1);
symbol1.setColor(new dojo.Color([255, 255, 0, 0.5]));
var city;
var values1 = [];
var testVals1={};
values1.push({name:""})
var features1 = results1.features;
dojo.forEach (features1, function(feature1) {
city = feature1.attributes.mname;
if (!testVals1[city]) {
testVals1[city] = true;
values1.push({name:city,shape:feature1.geometry,centroid: feature1.geometry.type === "point" ? feature1.geometry : feature1.geometry.getCentroid()}); // RIYAS: set shape to list store
var dataItems1 = {
items: values1
var store1 = new dojo.store.Memory({data:dataItems1});
dijit.byId("mySelect1").store = store1;
var resultFeatures1 = results1.features;
for (var i = 0, il = resultFeatures1.length; i < il; i++) {
var graphic1 = resultFeatures1;
graphic1.setSymbol(symbol1);
graphic1.setInfoTemplate(infoTemplate1);
map.graphics.add(graphic1);
var extent1 = esri.graphicsExtent(results1.features);
map.setExtent(extent1.expand(1.0), true);
dijit.byId("mySelect1").on("change", function () {
var city = dijit.byId("mySelect1").value;
var centroid = dijit.byId("mySelect1").item.centroid;
if (city !== 'ALL') {
var layerDefs1 = [];
layerDefs1[2] = "mname = " + "'" + city + "'";
layerDefs1.visibleLayers = [2];
map.setExtent(dijit.byId("mySelect1").item.shape.getExtent(infoTemplate1).expand(1.7)); // RIYAS: Get shape from list store and zoom to its extent
executeIdentifyTask("mname = '" + city + "'", centroid);
var queryTask2 = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer/3");
var query2= new esri.tasks.Query();
query2.outFields = ["dname", "mname","vname"];
query2.returnGeometry = true;
query2.outSpatialReference = map.spatialReference; // RIYAS: Set query to return shape in map's spatial reference
query2.where = "vname<> '' and dname='"+dijit.byId("mySelect").value+"'and mname='"+dijit.byId("mySelect1").value+"'"
//query1.where = "mname<> '' and dname='"+dijit.byId("mySelect").value+"'"
queryTask2.execute(query2,populateList2);
function populateList2(results2) {
var vill;
var values2 = [];
var testVals2={};
values2.push({name:""})
var features2 = results2.features;
dojo.forEach (features2, function(feature2) {
vill = feature2.attributes.vname;
if (!testVals2[vill]) {
testVals2[vill] = true;
values2.push({name:vill,shape:feature2.geometry,centroid: feature2.geometry.type === "point" ? feature2.geometry : feature2.geometry.getCentroid()}); // RIYAS: set shape to list store
var dataItems2 = {
items: values2
var store2 = new dojo.store.Memory({data:dataItems2});
dijit.byId("mySelect2").store = store2;
var resultFeatures2 = results2.features;
for (var i = 0, il = resultFeatures2.length; i < il; i++) {
var graphic2 = resultFeatures2;
graphic2.setSymbol(symbol1);
graphic2.setInfoTemplate(infoTemplate2);
map.graphics.add(graphic2);
var extent2 = esri.graphicsExtent(results2.features);
map.setExtent(extent2.expand(1.0), true);
dijit.byId("mySelect2").on("change", function () {
var vill = dijit.byId("mySelect2").value;
var centroid = dijit.byId("mySelect2").item.centroid;
if (vill !== 'ALL') {
layerDefs1[2] = "vname = " + "'" + vill + "'";
map.setExtent(dijit.byId("mySelect2").item.shape.getExtent(infoTemplate2).expand(1.7)); // RIYAS: Get shape from list store and zoom to its extent
executeIdentifyTask("vname = '" + vill + "'", centroid);
var queryTask3= new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/HOUSING/SRIKHOUSAP/MapServer/0");
var query3= new esri.tasks.Query();
query3.returnGeometry = true;
query3.outFields = ["*"];
query3.outSpatialReference = map.spatialReference; // RIYAS: Set query to return shape in map's spatial reference
query3.where = "dname='"+dijit.byId("mySelect").value+"'and mname='"+dijit.byId("mySelect1").value+"'and vname='"+dijit.byId("mySelect2").value+"'"
queryTask3.execute(query3,populateList3);
function populateList3(results3) {
symbol1.setSize(1);
var items123 = arrayUtils.map(results3.features, function (result3) {
var graphic = result3;
return result3.attributes;
var FID;
var values3 = [];
var item123 = [];
var testVals3={};
values3.push({name:""})
var features3 = results3.features;
dojo.forEach (features3, function(feature3) {
FID = feature3.attributes.FID;
if (!testVals3[FID]) {
testVals3[FID] = true;
//values3.push({name:ben_id,shape:feature3.geometry,centroid: feature3.geometry.type === "point" ? feature3.geometry : feature3.geometry.getCentroid()}); // RIYAS: set shape to list store
values3.push(feature3.attributes);
/*values3.push({"ben_id":ben_id,
"ben_name": feature3.attributes.ben_name,
"dname": feature3.attributes.dname,
"father_nam": feature3.attributes.father_nam,
"mname": feature3.attributes.mname,
"scheme_nam": feature3.attributes.scheme_nam,
"uid": feature3.attributes.uid,
"vname": feature3.attributes.vname,
var dataItems3 = {
identifier: 'FID',
label: 'FID',
items: item123
console.log(values3);
var store3 = new ItemFileReadStore({data:dataItems3});
var grid = registry.byId("grid");
grid.setStore(store3);
grid.on("rowclick", onRowClickHandler);
map.centerAndZoom(center, zoom);
//map.graphics.clear();
var resultFeatures3 = results3.features;
for (var i = 0, il = resultFeatures3.length; i < il; i++) {
var graphic3 = resultFeatures3;
graphic3.setSymbol(symbol1);
graphic3.setInfoTemplate(infoTemplate3);
map.graphics.add(graphic3);
var extent2 = esri.graphicsExtent(results3.features);
function onRowClickHandler(evt) {
var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).FID;
var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
return ((graphic.attributes) && graphic.attributes.FID === clickedTaxLotId);
if ( selectedTaxLot.length ) {
map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
function resizeMap() {
//Handle browser resize
clearTimeout(resizeTimer);
resizeTimer = setTimeout(function() {
map.resize();
map.reposition();
}, 800);
</script>
</head>
<body class="claro" oncontextmenu="return false">
<!-- <div class="title">
<div class="logo"> <a href="http://elandts.cgg.gov.in/"><img src="http://elandts.cgg.gov.in:80/website/images/TSlogo.png" width="80" height="80" alt="logo"/>
<h1> Land Regularization Management System <br><span>Government of Telangana </span></h1> </a>
</div>
<div class="cm">
<div class="pull-right">
<img src="http://elandts.cgg.gov.in:80/website/images/cm.png" style="" class="img-responsive" alt="cm" width="50"/> <br>
<h2> Sri K.Chandrasekhar Rao <br>
<span> Hon'ble Chief Minister of Telangana</span> </h2>
<br clear="all">
</div> -->
<div id="main" style="width:2024px; height:1012px; border:1px solid #000;"
dojotype="dijit.layout.BorderContainer"
design="headline"
gutters="true">
<div id="header"
dojotype="dijit.layout.ContentPane"
region="left"
style="height:25px;">
<select id="mySelect"
dojotype="dijit.form.ComboBox"
style="width:300px;font-size:18px;"
autoComplete="true"
forceValidOption="false"
value="Select a District"></select> <BR> <BR>
<select id="mySelect1"
value="Select a Mandal"></select> <BR> <BR>
<select id="mySelect2"
value="Select a Village"></select> <BR> <BR>
<button data-dojo-type="dijit.form.Button" onClick="veTileLayer.setMapStyle(esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL);">Aerial</button>
<button data-dojo-type="dijit.form.Button" onClick="veTileLayer.setMapStyle(esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL_WITH_LABELS)">Aerial with labels</button>
<button data-dojo-type="dijit.form.Button" onClick="veTileLayer.setMapStyle(esri.virtualearth.VETiledLayer.MAP_STYLE_ROAD)">Roads</button>
<div id="map"
region="center"
style="border:1px solid #000;margin:5px">
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">
<table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'11', rowSelector:'20px'">
<thead>
<tr>
<th field="FID"width="30%">FID</th>
<th field="ben_id"width="30%">BENEFICIARY ID</th>
<th field="ben_name"width="30%" >BENEFICIARY NAME</th>
<th field="father_nam" width="30%">FATHERS NAME</th>
<th field="uid" width="30%">AADHAR NO </th>
<th field="scheme_nam" width="30%">SCHEME NAME</th>
<th field="lat" width="30%">LATITUDE</th>
<th field="long" width="30%">LONGITUDE</th>
<th field="dname" width="30%">DISTRICT</th>
<th field="mname" width="30%">MANDAL </th>
<th field="vname" width="30%">VILLAGE</th>
</tr>
</thead>
</table>
<div style="position:relative;">
</body>
</html>
thanks
satya
