I want to show ENC chart in my WPF app but getting these error. I have also attached screen shot of error. I have set symbols path and manifest file too but no success.
<Window x:Class="ArcGISApp1.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:esri="http://schemas.esri.com/arcgis/runtime/2013" xmlns:hydro="clr-namespace:Esri.ArcGISRuntime.Hydrographic;assembly=Esri.ArcGISRuntime" Title="MainWindow" Height="350" Width="525"> <Grid> <esri:MapView x:Name="MyMapView" LayerLoaded="MyMapView_LayerLoaded"> <esri:Map> <!--<esri:ArcGISTiledMapServiceLayer ID="Basemap" ServiceUri="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>--> <esri:GroupLayer ID="Hydrographic"> <hydro:HydrographicS57Layer ID="PK2NB58Z" Path="US5TX51M.000"> </hydro:HydrographicS57Layer> </esri:GroupLayer> </esri:Map> </esri:MapView> </Grid></Window>
I think there is no issue at all in code. I dont understand what is the reason..........!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It seems that cause here is setting MapView and Maps SpatialRefernce correctly. It is normally taken from the first layer but GroupLayer doesn't have one.
Here is code that should work
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">esri:</SPAN>MapView</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">x:</SPAN>Name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>MyMapView<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">LayerLoaded</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>MyMapView_LayerLoaded<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">esri:</SPAN>MapView</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
<SPAN class="keyword token">using</SPAN> Esri<SPAN class="punctuation token">.</SPAN>ArcGISRuntime<SPAN class="punctuation token">.</SPAN>Controls<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">using</SPAN> Esri<SPAN class="punctuation token">.</SPAN>ArcGISRuntime<SPAN class="punctuation token">.</SPAN>Geometry<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">using</SPAN> Esri<SPAN class="punctuation token">.</SPAN>ArcGISRuntime<SPAN class="punctuation token">.</SPAN>Hydrographic<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Diagnostics<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Windows<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">namespace</SPAN> HydragraphicLayersDemo <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">partial</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">MainWindow</SPAN> <SPAN class="punctuation token">:</SPAN> Window <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">private</SPAN> HydrographicS57Layer _layer<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">public</SPAN> <SPAN class="token function">MainWindow</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">InitializeComponent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Force to use WebMercator which is normally taken from the first layer</SPAN> <SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> SpatialReference <SPAN class="operator token">=</SPAN> SpatialReferences<SPAN class="punctuation token">.</SPAN>WebMercator<SPAN class="punctuation token">,</SPAN> InitialViewpoint <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ViewpointExtent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Envelope</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> SpatialReferences<SPAN class="punctuation token">.</SPAN>WebMercator<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Create hydrographic layer and set it to the layers collection</SPAN> _layer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">HydrographicS57Layer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> ID <SPAN class="operator token">=</SPAN> <SPAN class="string token">"US1WCO1M"</SPAN><SPAN class="punctuation token">,</SPAN> Path <SPAN class="operator token">=</SPAN> <SPAN class="string token">@"C:\Temp\HydragraphicLayersDemo\HydragraphicLayersDemo\bin\Debug\us1wc01m\US1WC01M.000"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN>Layers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN>_layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Set map to view</SPAN> MyMapView<SPAN class="punctuation token">.</SPAN>Map <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Zoom to the layer when the layer is loaded</SPAN> <SPAN class="token function">ZoomToHydrographicLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">async</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">ZoomToHydrographicLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">try</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// wait until all layers are loaded</SPAN> <SPAN class="keyword token">await</SPAN> MyMapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">LayersLoadedAsync</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> Envelope extent <SPAN class="operator token">=</SPAN> _layer<SPAN class="punctuation token">.</SPAN>FullExtent<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Zoom to full extent</SPAN> <SPAN class="keyword token">await</SPAN> MyMapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetViewAsync</SPAN><SPAN class="punctuation token">(</SPAN>extent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">Exception</SPAN> ex<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> MessageBox<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Error occurred : "</SPAN> <SPAN class="operator token">+</SPAN> ex<SPAN class="punctuation token">.</SPAN>Message<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Sample error"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">MyMapView_LayerLoaded</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">object</SPAN> sender<SPAN class="punctuation token">,</SPAN> LayerLoadedEventArgs e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">.</SPAN>LoadError <SPAN class="operator token">==</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> Debug<SPAN class="punctuation token">.</SPAN><SPAN class="token function">WriteLine</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">string</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">Format</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Error while loading layer : {0} - {1}"</SPAN><SPAN class="punctuation token">,</SPAN> e<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">.</SPAN>ID<SPAN class="punctuation token">,</SPAN> e<SPAN class="punctuation token">.</SPAN>LoadError<SPAN class="punctuation token">.</SPAN>Message<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
It sounds like the hydrographic_s57.dat file cannot be found. If you are running the app on your dev machine against the installed SDK then it should be in "C:\Program Files (x86)\ArcGIS SDKs\DotNet10.2.7\WindowsDesktop\bin\arcgisruntime10.2.7\resources\symbols\hydrographic_s57". Or if you have added a deployment manifest to your and selected to include the hydrographic option then it should be in "<your_app_folder>\arcgisruntime10.2.7\resources\symbols\hydrographic_s57". You should not need to set the symbols path unless you have included the .dat file elsewhere in your app/solution.
Can you see the dat file in either of those locations?
Cheers
Mike
Yes .dat file is placed in both locations. Now I have commented symbols path and getting the error "failed to load cell info".
Why there is difference in using sdk for .net and sdk for wpf? I have also seen examples for wpf sdk n these work in totally different way as we can embed the S57Cell object inside HydrographicS57Layer. First time I m using ArcGIS sdk for .net and have never used any previous versions and also not used sdk for wpf.
Can u suggest any other to do or is there any complete sample available? the samples available to download are not compiling.......
Just to clarify that ArcGIS Runtime for .NET and ArcGIS Runtime for WPF are 2 different SDKs. ArcGIS Runtime for WPF is older SDK that is replaced by ArcGIS Runtime for .NET (which contains SDKs for WPF, Windows Store and Windows Phone). ArcGIS Runtime for .NET API has been redesigned and modernized which means that the API is not the same as the old one.
Could you post which samples you are building? If you are using ArcGIS Runtime for .NET you should be using this repository. It has couple samples that uses hydrographic layer. Make sure that you follow these steps to get the reference changed so you can deploy the files. Could you paste compile error information too?
Yes I knew that .NET sdk has been overhauled and already explored a bit. As to samples, I hate when any sample on net use NuGet package and myself is uncomfortable with it. I have downloaded right samples, first I was missing data folder which again downloaded n then the package error; mean unable to get it removed from solution.
Actually what I need in my app is that I just need to show ENC charts (.000). Do I need to be online to show this? I have attached the error screen shot in question and the code is also pasted there. Once I uncomment the line
<!--<esri:ArcGISTiledMapServiceLayer ID="Basemap".....
I dont get any error but I have to be online to show the map. I dont need this map, I have S57 ENC files and want to show these maps.
At the moment I have no urgency of compiling samples but we are exploring few SDKs and this is obviously seem to be the best. We have good experience in .NET and WPF. I m not understanding what is wrong as why I m unable to get the ENC charts rendered. If u can provide me with a separate sample to show ENC files offline, it would help us a lot as our app will always be in disconnected mode....
If there is still anything u need to explain me, let me know plz.
You can contact your distributor for the licensing. Also have a look to licensing documentation.
Sorry for the late reply...As I asked previously can I add custom drawing in charts?
Is there any page where I can see what can I do and what not?
You can work with GraphicsOverlays (On top of MapView.Map.Layers preferred way) or using GraphicsLayers (inside of MapView.Map.Layers collection) to add custom object to the MapView. Have a look samples in https://github.com/Esri/arcgis-runtime-samples-dotnet/tree/master/src/Desktop/ArcGISRuntimeSamplesDesktop/Samples/GraphicsLayers
Thanks. We also have contacted our local distributor but still confused about licensing.
As soon as we are exploring many things are coming to mind..is it possible to combine two maps such as loading tpk file and then ENC?
I did but as soon as I zoom to hydro layer the loaded tpk disappears. I tried to merge both but got error "Mix spatial references are not supported". Any suggestion?
You can use any number of layers in your map where they might be hydrographic, tile layers (local or online), feature layers etc.. Just make sure that you have all the data in the same Spatial Reference since we don't support multiple spatial references in a one MapView/Map.
When using TPKs make sure that you data from the area and all the scales you want to show. Read more about creating tile packages from http://desktop.arcgis.com/en/arcmap/10.3/map/working-with-arcmap/about-tile-packages.htm
I mean if I have tpk file. I make this as my basemap n then load ENC on top of it...?
Yep, that's the way. Remember that you can dynamically add / remove layers too but just make sure that the tpk is rendered below the ENC on top of it. (read: lower index in layers collection).
I did that way n tpk loaded and rendered but as soon as ENC loaded tpk disappeared!!!!!!!!!!
Could you provide me the code that you are using so I can have look what's going on?
Oops!!! my mistake. Maps were far apart when I zoom to one the other is placed on its location. I was also wondering why this was so!! When I tested to load two ENCs n tpk n zoomed separately each one with button each was placed on its location. Thanx for help.
Its been a while to contact u as we are exploring other things too and engaged in other things also. As I asked previously I want to add Custom drawing in my app but I think we r limited only to using the Drawing shapes available in SDK like SimpleMarkerSymbol, SimpleLineSymbol with fixed styles!!!! If I want to add any type of symbol, probably made with WPF drawing, so how can I do this. I dont want to use PictureMarkerSymbol. My point actually is that how can I add shape other than those available in SDK? Do I have to extend from the Symbol Class or other way such as WPF drawing can be added but how in both cases?
At the moment we don't provide integration between wpf drawings and runtime out of the box so your options are
- Use existing graphic symbols (picture markers, simple markers, composite markers, CIM etc...)
- Write your symbols in XAML and transform that to picture and use picture markers. Get's full map support. Works only for points.
- Use map overlays instead graphics. Not as performant and doesn't support hit testing out of the box.
- Draw your graphics on top of the map and integrate that with the map interactions.
Since you don't want to use picture markers, you can try to use overlays or write your own drawings on top of the map (using canvas or similar) and then write integration between that and map view. You need to make sure that you respect the spatial reference of the map with your drawings.
This is where we r actually stuck...we need custom drawing with hit testing. Is there any sample available for the suggestions u have given specially interaction btw map view and canvas or any other?
Can we extend the Symbol Class? if yes which methods to override to make custom symbols? I m not sure this is possible?
Another team in our dept worked on SharpMap which has provision for custom drawings. I believe ArcGIS SDK is much more powerful and professional SDK and hope it will provide us with many good features unless these r unfolded and explored....
Many things depends on what kind of drawings you need to write and how the hit test is related to that. We don't have examples on about custom drawings on top of the map approach but I know that there are customers that have implemented that so it is doable. For picture markers and overlay you can find some tips from https://www.arcgis.com/home/item.html?id=71e82397445a47629e45f15161ca4761
I will have a look and see if it is of any use to us
Hi, I hva eseen ur ArcGIS Runtime SDK for .NET: Tips and Tricks video but in the attached samples there is no demo project for funky symbols..!! Can u provide me that bcz we r stuck only in specialized symbols using ArcGIS. If u have any other samples or some tips for custom symbols plz provide us. Thnaks.
