I can successfully change the point symbol used in the measurement widget in 3.13. However, the point symbol in the results is too small to see. Is there a way to resize the symbol in the results? Please see the attached png.
thanks,
Janice.
Janice,
So I found a workaround for this issue. Here is a full sample:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Measure Tool</title> <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css"> <style> html,body { height:100%; width:100%; margin:0; } body { background-color:#FFF; overflow:hidden; font-family:"Trebuchet MS"; } #map { padding:0px; } #rightPane{ width:300px; } </style> <script src="http://js.arcgis.com/3.13/"></script> <script> var map; require([ "esri/map", "esri/dijit/Measurement", "esri/dijit/Scalebar", "esri/symbols/PictureMarkerSymbol", "esri/symbols/SimpleLineSymbol", "dojo/query", "dojo/_base/lang", "dojo/dom-attr", "dojo/parser", "dijit/layout/BorderContainer" ], function ( Map, Measurement, Scalebar, PictureMarkerSymbol, SimpleLineSymbol, query, lang, domAttr, parser, BorderContainer ) { parser.parse(); map = new esri.Map("map", { basemap: "hybrid", center: [-34.541, 32.843], zoom: 3 }); map.on('load', function(map) { initToolbar(map); }); function initToolbar(mymap) { //define a new line symbol and point symbol to use for measure tools var pms = new PictureMarkerSymbol("images/flag.png",24,24); pms.setOffset(9,11); var sls = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DOT, new dojo.Color([255,0,0,0.55]), 4); var measurement = new Measurement({ map: map, lineSymbol:sls, pointSymbol:pms }, dojo.byId('measurementDiv')); measurement.startup(); measurement.setTool("area",true); var node = query(".esriLocationResultSymbol > *")[1]; domAttr.set(node, "width", 24); domAttr.set(node, "height", 24); var node2 = query(".esriLocationResultSymbol > svg > image")[1]; dojo.removeAttr(node2, "x"); dojo.removeAttr(node2, "y"); dojo.removeAttr(node2, "transform"); } }); </script> </head> <body class="claro"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:true" style="width:100%; height:100%;"> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'"> <div>Use the measurement widget to calculate area, find the distance between locations and display the current mouse location. </div> <div id="measurementDiv"></div> </div> </div> </body> </html>
Hey Robert,
The app is not currently public... at least not the version I am working on. I am trying to upgrade to 3.13 before pushing it out to the public. Our public version is at 3.9... Skagit County iMap .
I am using your suggestion of console.info(measurement) to investigate the object but can not find where the changes are getting may by the code you provided. I am assuming that this line of code: query(".esriLocationResultSymbol > *")[1]; finds the second occurrence of the class in the widget. Is there an easy way to locate this in the console. I am using ie11.... I suppose I should try firefox for different developer tools.
How / Where did you find .esriLocationResultSymbol? Maybe I can use something more generic so it works on my users workstations and not just mine.
Still thinking on it,
Is the app public?
Robert,
This solution only works on my development machine. When I have other people run my application, they do not get the resized image in the measurement results. They still get the itty-bitty one. I'm done for the day, will look at it again tomorrow.
I am not really sure that I follow what you are doing here but it does work!
thank-you for your help!
Your suggestion does work if I use the default marker symbol that the measurement widget uses. the issue I am having is trying to resize a custom marker symbol. I tried your code in the sandbox for the sample and it did not work there either. The sample is located at: ArcGIS API for JavaScript Sandbox
Let me know if I am way off on this.... it is entirely possible that I am doing something funky!
Sorry my original post did not really state that I was using a custom symbol.
The image in your attachment how are you specifying it? Is that the correct image? Like Radek confirms I had no problem changing the size of the image using the provided css.
I can confirm Robert's solution works for me. Just added his code to my css template and works without any problem.
Tested in Firefox 37.02.
Hi Robert,
I did try this but it made no change for me. If I go into the development tools in ie I can change this manually and it helps a little but still it does not persist.
getting the unique selector from Firefox I get:
tr.esriMeasurementTableRow:nth-child(3) > td:nth-child(1) > div:nth-child(1) > svg:nth-child(1) > image:nth-child(2)
I have tried this in Firefox, Chrome, and IE11 with no luck.
There is not a great way to do this but this will work:
.esriMeasurement .esriMeasurementResultTable tr:nth-of-type(3) > td > img{ height: 50px; width: 50px; }
