When viewing the summery widget in the web dashboard all i see is "No Data", but when viewed in the windows application it comes up correctly. Is there a known issue with the summary widget in the web viewer?
thanks for any help or suggestions.
Tom
I am having the exact same issue. Some widgets work and some don't. I found this link, towards the bottom it says "Not all of the widgets available in the Windows version are in the Browser version. We are working to reach parity between the platforms with a set of focused releases between now and July."
Operations Dashboard in a browser | ArcGIS Blog
Good luck.
Hola Tom y Juan,
This is Juan of Support Services, and this is a logged bug within our system and our developers have been made aware of this issue. We appreciate you both posting this and bringing this to our attentions, and I am including the bug information for you both. You can always reach out to us in Support Services for an update on the status of this bug. Thanks, Tom y Juan!
BUG-000094326 - The browser version of the Operations Dashboard for ArcGIS (Desktop version) returns no data for the Summary widget.
Staus: New
Juan
Any idea of when this might be fixed? We should be able to expect that our dashboards will show correctly in the browser when we publish them. I have this issue with the summary widget and the indicator widget.
Thanks!
Hi Juan,
This link is a blog when Operations Dashboard first released the web version in 2014 and any all of the widgets should be performing the same now. I'm looking into the bug that Juan mentioned below.
Chris
Is it that the count shows null or that the count is different? What does the indicator widget look like?
the widget shows nothing at all for the summary and indicator. See attached image.
Hi Leah-
I dug a little deeper on this and there was a bug with Server that was fixed at 10.4- specifically, the outStatistics query of a MapServer returns incorrect results when the dataset is non-versioned archived data. What version of server are you using?
I'm on 10.4. This is a not GIS data, but a query layer from a production Oracle database (non-spatial).
I'm wondering if this should be a new bug then. The issue that was logged seems to have fixed the mapserver problem, but doesn't mean it would address a non-spatial table....
The layer is a query layer, that is being mapped and pushed up as a feature service. The summary and indicator widgets are just counting the features that are changing. So the layer is spatial when it gets to the dashboard. This works in the Ops Dashboard when I'm developing it as a single screen dashboard, but does not work in the web browser...only the windows app. So this seems like the same bug to me?
hello,
Im also facing the same issue, its not just with the summary widget, i guess the problem is from the map service it self.
Did you guys find a solution for this?
im using a mapservice not a feature service
im using portal 10.3.1, sql server 2012
my data isnt versioned
Also its been 2 weeks that im facing a weird behavior of the windows dashboard.
Everytime i try to add the query widget, the dashboard gives me ana error and closes.
also adding christopher Christopher Olsen
Thank you guys.
I hate to bring up an old thread but.. i have looked on ESRI support at the BUG that was added back in February, I've need seen a fix or work around or even an update on this .
Can anyone advice if they have found a work around ?
Summery?
The bug was logged on a 10.3.1 server and we have seen it was fixed at 10.4. Do you have reproducible data that you can send that replicates the issue? I would like to test this against the latest builds. Thanks!
Can you post or PM me the data that shows this issue? I haven't been able to reproduce it.
I just wonder why you named it Summery
Susan Smith, GISP, HzP, GIS Coordinator
Information Technology and Assurance
Arizona Department of Emergency and Military Affairs (DEMA)
5636 E. McDowell Road, Bldg. 5101, Phoenix, AZ 85008
(w) (602) 464-6344 |
susan.smith@azdema.gov | dema.az.gov ( https://dema.az.gov/ )
How am I doing? Please take a few moments to answer a few questions so that I can improve my service to you:
https://www.surveymonkey.com/r/68MF5XT
>>> Christopher Olsen <geonet@esri.com> 1/13/2017 11:01 AM >>>
GeoNet ( https://community.esri.com/?et=watches.email.thread )
Re: Summery Widget in the web dashboard not working.
reply from Christopher Olsen ( https://community.esri.com/people/colsen-esristaff?et=watches.email.thread ) in Operations Dashboard for ArcGIS - View the full discussion ( https://community.esri.com/message/659187-re-summery-widget-in-the-web-dashboard-not-working?commentID=659187&et=watches.email.thread#comment-659187 )
Reply to this message by replying to this email, or go to the message on GeoNet ( https://community.esri.com/message/659187-re-summery-widget-in-the-web-dashboard-not-working?commentID=659187&et=watches.email.thread#comment-659187 )
Start a new discussion in Operations Dashboard for ArcGIS by email ( mailto:discussions-community-gis-applications-operationsdashboardfor--arcgis@mail.geonet.esri.com ) or at GeoNet ( https://community.esri.com/choose-container.jspa?contentType=1&containerType=14&container=2121&et=watches.email.thread )
Following Re: Summery Widget in the web dashboard not working. ( https://community.esri.com/message/659187-re-summery-widget-in-the-web-dashboard-not-working?commentID=659187&et=watches.email.thread#comment-659187 ) in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe ( https://community.esri.com/unsubscribe.jspa?email=susan.smith@azdema.gov&token=74b187df3d2d01cf2c37587ad1a3bd25457c4759e507ca315ac40edd88b757ff ) instantly from GeoNet, or adjust email frequency in your email preferences ( https://community.esri.com/user-preferences!input.jspa )
The widget is called Summary.... The person who made this thread incorrectly spelled it.
