It appears that the geometry service is being overwritte each time the config file gets saved.As I use my own Geometry Service, this behaviour is not so helpful.
When I use ArcGIS Online maps I get a Portal Error
I see there is an extra parameter for ArcGIS online maps to specigy an icon.This does not seem to be a documented feature.
Should we be specifying this for Bing and Other Base Map Servies?
It appears there are copy errors, I copy up to a DMZ, so I think this is probably permissions and/or flash related, but I thought I would mention it.
The apps and popups folders are not copied up though, if this is important.These two folders are for supporting default configs that comes with separate download of compiled Flex viewer and Flex viewer source code. This two folders are not included with the compiled viewer that comes with App builder.I didn't log into ArcGIS.com before starting so I guess that is why I get a portal error.By default, you dont have to login to ArcGIS.com. In this case publicly shared items will be displayed. You need to login to ArcGIS.com to see content that you own or shared to you.As for the Basemaps icons, I don't get an icon when adding an ArcGISOnline basemap or an example ArcGIS server Layer.I also tested this from a manual copy of flexviewer 3I get no icons for the above basemaps. When I put this url in a web browser it finds the icon - the url includes arcgis.comI copied the icon to a place on my server and still don't see it in teh mapswitcher!?ery/MapServer" visible="true"/>IanCould you try something like this? does it show icon?<layer type="tiled" label="Imagery" icon="https://www.arcgis.com/sharing/rest/content/items/86de95d4e0244cba80f0fa2c9403a7b2/info/thumbnail/tempimagery.jpg" url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imag
