# -*- coding: cp1252 -*- """ ConeLineBuffer.py Author : fpr Many thank to rba for algorythm Date: 01/25/2011 Description : Create cone from line buffer with min buffer value at the start line and with max buffer value at the end line. Warning: you must have : 1. min value <> max value 2. start point of line always have the min value 3. end point of line always have the max value Parameters list : Parameters properties Name Data type Type Direction Multiple value Default Filter Obtain from argv[1] Input SHP Feature class Required Input No argv[2] Input min radius long Required Input No argv[3] Input max radius long Required Input No ---------------------------------------------------------------------- """ # Import system modules import arcpy, os def getScratchWorkspace(outDataset): # Set the scratchWorkspace environment to local file geodatabase outPath = os.path.dirname(outDataset) arcpy.CreateFileGDB_management(outPath, "scratch.gdb", "CURRENT") scratchWorkspace = os.path.join(outPath, "scratch.gdb") arcpy.env.scratchWorkspace = scratchWorkspace return scratchWorkspace def getStartPointOfLine(line): """ Return first point of line """ pointStart = arcpy.Point() pointStart = line.firstPoint return pointStart def getEndPointOfLine(line): """ Return end point of line """ pointEnd = arcpy.Point() pointEnd = line.lastPoint return pointEnd def bufferPoint(point, dis, scratchWorkspace, outName): # Process : buffer first point of line pointGeometry = arcpy.PointGeometry(point) outBufferPoint = scratchWorkspace + "\\" + outName if arcpy.Exists(outBufferPoint): outBufferPoint = outBufferPoint + "1" arcpy.Buffer_analysis(pointGeometry, outBufferPoint, dis, "FULL", "ROUND", "NONE", "") return outBufferPoint def creerPolyligneSelonPoint(PointDebut, arcTan, longueurLigne): import math """Retourne un objet ligne à partir du point de début, un angle et une longueur. INPUTS: point de début, l'angle de la ligne, une longueur OUTPUT: objet ligne """ #Créer une polyligne array = arcpy.Array() array.add(PointDebut) # Détermine le point de fin selo PointFin = arcpy.Point() PointFin.X = PointDebut.X - math.sin(arcTan)* longueurLigne PointFin.Y = PointDebut.Y - math.cos(arcTan)* longueurLigne array.add(PointFin) polyline = arcpy.Polyline(array) array.removeAll() return polyline def arcTanEntreDeuxPoints(PointDebut, PointFin): import math """Retourne l'arc tan entre deux points. INPUTS: point de début et point de fin OUTPUT: arcTan """ arcTan = math.atan2((PointDebut.X - PointFin.X),(PointDebut.Y - PointFin.Y)) return arcTan def distanceRelative(Distance, Pourcentage): """Retourne la distance issue du pourcentage souhaitée. INPUTS: distance OUTPUT: 50 pourcent de la distance par exemple """ distanceRel = (float((Distance)) * float(Pourcentage))/100 return distanceRel def distanceEntreDeuxPoints(PointDebut, PointFin): import math """Retourne la distance entre deux points. INPUTS: point de début et point de fin OUTPUT: distance """ distance = math.sqrt((PointDebut.X - PointFin.X)**2 + (PointDebut.Y - PointFin.Y)**2) return distance def getTangentIntersect(radiusCircleMin, radiusCircleMax, dist2points): """ Return intersection point of circle tangent a with the line """ GetTangentIntersect = (radiusCircleMin * dist2points)/ (radiusCircleMax - radiusCircleMin) return GetTangentIntersect def deleteFcStoreScratchWorkspace(pathFGDB, wild_card): arcpy.env.workspace = pathFGDB fcs = arcpy.ListFeatureClasses(wild_card) for fc in fcs: arcpy.Delete_management(fc) return def run_ConeLineBuffer(): inFC = r"D:\fpr10_PYDEV\fprPYDEV_v10\ConeLineBuffer\data\lines.shp" # CHANGE inRadiusBufferMin = 50 # CHANGE inRadiusBufferMax = 300 # CHANGE return create_ConeLineBuffer(inFC, inRadiusBufferMin, inRadiusBufferMax) def create_ConeLineBuffer(inFC, inRadiusBufferMin, inRadiusBufferMax): arcpy.AddMessage("*"*10) arcpy.AddMessage("Process : Create cone line buffer ...\nrunning ...") arcpy.OverWriteOutput = True # Process: Define the scratch workspace sw = getScratchWorkspace(inFC) arcpy.env.workspace = sw # Process: get path of input ... outPath = os.path.dirname(inFC) # Process: prepare SQL query SHP or GDB OID = arcpy.Describe(inFC).OIDFieldName delimitedField = arcpy.AddFieldDelimiters(inFC, OID) # Iterate through the lines in the cursor sRows = arcpy.SearchCursor(inFC) for sRow in sRows: index = sRow.getValue(OID) shapeLine = sRow.Shape # Process : Get start and end point of line startPoint = getStartPointOfLine(shapeLine) endPoint = getEndPointOfLine(shapeLine) # Process : Create buffer for start/end line bufferMin = bufferPoint(startPoint, str(inRadiusBufferMin) + " Meters", sw, "_bufferMin") bufferMax = bufferPoint(endPoint, str(inRadiusBufferMax) + " Meters", sw, "_bufferMax") ## Process : Search point a dist2points = distanceEntreDeuxPoints(startPoint, endPoint) a = getTangentIntersect(inRadiusBufferMin, inRadiusBufferMax, dist2points) radiusCircleMax = (dist2points + a)/2 ## Process : Create circle c1 (Max) # Process: Get arctan of line valeurArcTan = arcTanEntreDeuxPoints(endPoint, startPoint) # Process: create line lineCircleMax = creerPolyligneSelonPoint(endPoint, valeurArcTan, radiusCircleMax) # Process : endPtCircleMax = getEndPointOfLine(lineCircleMax) # Process : circleMax = bufferPoint(endPtCircleMax, radiusCircleMax, sw, "_circleMax") # Process : Intersect BufferMaw with CircleMax to get # Process: Intersect intersectMax = sw + "\\_intersectMax" arcpy.Intersect_analysis(bufferMax + ";" + circleMax, intersectMax, "ALL", "", "POINT") ## Process : Create circle c2 (Min) radiusCircleMin = a/2 # Process: create line lineCircleMin = creerPolyligneSelonPoint(startPoint, valeurArcTan, radiusCircleMin) # Process : endPtCircleMin = getEndPointOfLine(lineCircleMin) # Process : circleMin = bufferPoint(endPtCircleMin, radiusCircleMin, sw, "_circleMin") # Process : # Process : Intersect BufferMaw with CircleMax to get # Process: Intersect intersectMin = sw + "\\_intersectMin" arcpy.Intersect_analysis(bufferMin + ";" + circleMin, intersectMin, "ALL", "", "POINT") # Process : arcpy.env.workspace =sw arcpy.Merge_management([intersectMin, intersectMax], "_intersectMerge") # Process: Minimum Bounding Geometry arcpy.MinimumBoundingGeometry_management("_intersectMerge", "_Bounding", "CONVEX_HULL", "ALL", "", "NO_MBG_FIELDS") # Process: Merge Bounding = sw + "\\_Bounding" arcpy.Merge_management([bufferMin, bufferMax, Bounding], "_Bounding_Merge") # Process: Dissolve Bounding_Merge = sw + "\\_Bounding_Merge" arcpy.Dissolve_management(Bounding_Merge, "result" + str(index), "", "", "MULTI_PART", "DISSOLVE_LINES") # Process : delete intermediate fc begin by "_" deleteFcStoreScratchWorkspace(sw, "_*") # Process: Merge all result feature classes ## Create a value table to hold names of input feature classes for Merge tool. vt = arcpy.ValueTable() fcs = arcpy.ListFeatureClasses("r*") for fc in fcs: vt.addRow(fc) outFC = os.path.join(outPath,"ConeLineBuffer.shp") arcpy.Merge_management(vt, outFC) # Process: Delete scratch workspace arcpy.Delete_management(sw) arcpy.AddMessage("Process: End") arcpy.AddMessage("*"*10) if __name__ == '__main__': run_ConeLineBuffer()
inFC = r"D:\fpr10_PYDEV\fprPYDEV_v10\ConeLineBuffer\data\lines.shp" # To change inRadiusBufferMin = 10 # To change inRadiusBufferMax = 100# To change
