I've tried publishing a hosted layer from ArcGIS Pro. It succeeds, and shows up in my AGOL content, but not as hosted layer. What am I doing wrong?
It appears you've shared a layer package from ArcGIS Pro to ArcGIS Online. This packages up the dataset and layer properties, enabling you to readily share it through your portal to others who want to download and unpack it.
This page covers how to share a web feature layer from ArcGIS Pro, including hosted Feature Layers.
Hope this helps,
Chris
How are you publishing? Can you provide a link to the service that is published?
I'm sharing as a hosted layer from within ArcGIS Pro. Here's the link to the item description page on AGOL.
http://ucmerced.maps.arcgis.com/home/item.html?id=cc409fa3f8dd4b46abe3b34721f7dba3
The layer is not shared publicly so I can't access it via that link. If you have access to Support you may want to open a case, they will be able to screen share with you and troubleshoot the issue.
OK, I don't know if I do or not, but will look into it. Thanks!
Actually, can I just share it and then you can look at it?
sure, I still don't know if I will be able to figure it out or not but it's a place to start
Oh dear, I could have sworn I did the Share Web Layer. Maybe that was an
earlier attempt. I will have to wait until I am back in the office next
week and just try again. Thanks for trying to help.
No Problem Amelia. ArcGIS Pro does bring a few additional ways to readily share data.
If this solves the issue please mark the answer as correct.
I'm sure your answer is correct, but I am also sure that I did try to share as a web layer and it didn't work. But that may be due to another problem. I'm suspecting the projection issue. When I get back to the office I will see if I can figure it out. But thanks very much for your help! Hopefully I won't be back on here next Tuesday with more questions. I wish there were a hard-copy of explicit instructions, I find navigating online help very frustrating. I keep coming across the same pages over and over, but they never solve my problem.
Yeah, it worked. Thanks again!
