Hi!
I would like to get information about the service urls privided at my onw portal.
So like to start with Esri::ArcGISRuntime::Portal, but how?
Thx in advance!
Norbert
Hi Norbert,
This documentation discusses how you sign into your Portal - Access the ArcGIS platform—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
To access items, see this topic - Access portal content—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
And to search, see this topic - Search for content—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
The high level workflow is:
- Create Portal object using your URL, and pass in credentials with username and password
- Load the Portal and wait fo it to be done loading
- Call findItems on the Portal object by passing in query parameters
- Get your desired Portal Item from this list
Hi Luke!Thanks for your quick answer 🙂
I tried my own URL "http://xyz.de" with credentials
After load i get doneLoading and errorOccured with:
Esri::ArcGISRuntime::Error: code=404, domain=0, extendedErrorType=0, message='Error transferring http://excgeo20.sl.defence-elec.de/sharing/rest/info?f=json - server replied: Not Found', additionalMessage='Error transferring http://excgeo20.sl.defence-elec.de/sharing/rest/info?f=json - server replied: Not Found'
Any ideas?
Norbert- are you on the same internal network? If not, is your portal accessible outside your network? Also, did you set up your proxy? It should be as simple as the code in the doc:
QUrl portalUrl <SPAN class="operator token">=</SPAN> <SPAN class="token function">QUrl</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fgeoportal.mycompany.com" target="_blank">http://geoportal.mycompany.com</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> Credential<SPAN class="operator token">*</SPAN> portal_Credential <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">Credential</SPAN><SPAN class="punctuation token">(</SPAN>portalUsername<SPAN class="punctuation token">,</SPAN> portalPassword<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> Portal<SPAN class="operator token">*</SPAN> onPremisesPortal <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">Portal</SPAN><SPAN class="punctuation token">(</SPAN>portalUrl<SPAN class="punctuation token">,</SPAN> portal_Credential<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">connect</SPAN><SPAN class="punctuation token">(</SPAN>onPremisesPortal<SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">&</SPAN>Portal<SPAN class="operator token">::</SPAN>loadStatusChanged<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> onPremisesPortal<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">(</SPAN>LoadStatus loadStatus<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>loadStatus <SPAN class="operator token">==</SPAN> LoadStatus<SPAN class="operator token">::</SPAN>Loaded<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> PortalInfo<SPAN class="operator token">*</SPAN> info <SPAN class="operator token">=</SPAN> onPremisesPortal<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">portalInfo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">qDebug</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><<</SPAN> info<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">portalName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> onPremisesPortal<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi Luke!
I use my own map example to load an arcgisonline basemap tu guarantee that internet access is working.
In the same example i configure this portal url without credentials:
new Esri::ArcGISRuntime::Portal(QStringLiteral("http://www.argis.com"));
or
new Esri::ArcGISRuntime::Portal(QStringLiteral("http://www.argis.com"), false);
After a few seconds:
2018-10-10 11:39:27.096 ERROR Portal |#| void SituationMap::Portal::onPortalDoneLoading(const Esri::ArcGISRuntime::Error &) Portal -> EsriError occured: Esri::ArcGISRuntime::Error: code=404, domain=0, extendedErrorType=0, message='Error transferring https://www.argis.com/sharing/rest/portals/self?f=json - server replied: Not Found', additionalMessage='Error transferring https://www.argis.com/sharing/rest/portals/self?f=json - server replied: Not Found' (SituationMap/Portal/portal.cpp:141)
2018-10-10 11:39:27.096 ERROR Portal |#| void SituationMap::Portal::onPortalErrorOccurred(const Esri::ArcGISRuntime::Error &) Portal -> EsriError occured: Esri::ArcGISRuntime::Error: code=404, domain=0, extendedErrorType=0, message='Error transferring https://www.argis.com/sharing/rest/portals/self?f=json - server replied: Not Found', additionalMessage='Error transferring https://www.argis.com/sharing/rest/portals/self?f=json - server replied: Not Found' (SituationMap/Portal/portal.cpp:132)
Is this maybe also not implemented on linux?
If it fails to load with http://arcgis.com, I think that suggests some sort of network issue. It works in general on Linux - we run full certification testing on all the supported platforms.
So, using http://xyz.de/arcgis i can connect to the portal anonymously.
After load and fetchBasemaps(), fetchFeaturedGroups(), fetchFeaturedItems(), fetchHomepageFeaturedContent() i can get the according model.
But the model content is not as expected:
Maybe i have to use login credentials?
Therefore i updated the ssl certificates.
Result:
errorCode 25, related to SSL...
What is my long term goal?
Any hints?
We have a sample for that. It uses Qt Quick, so the UI portions won't be relevant for you, but the Portal related code should be - arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_CppSamples/CloudAndPortal/ShowOrgBasemaps at master · Esri/arcgis-runtime-s…
You can see that once the Portal loads, we call fetchBasemaps - arcgis-runtime-samples-qt/ShowOrgBasemaps.cpp at master · Esri/arcgis-runtime-samples-qt · GitHub
Once basemapsChanged emits, you can access the BasemapListModel and display that in a view of some sort (like List or GridView) Portal Class | ArcGIS for Developers
The list model has roles for the thumbnail URL, name, etc - BasemapListModel Class | ArcGIS for Developers
Thank you for your answer.
As describes i need not just the basemapListModel.
More important are the (basic) services listed under "My Content" if i login as portal user (admin).
There are my services of type
Is it correct that this service list can´t be retrieved using the SDK?
Is there another?
Thx
here is some example code. you can modify your search string to find the different items you need. for example, you can specify type, tags, name, etc. Here are some details on how you can customize it - Search reference—ArcGIS REST API: Users, groups, and content | ArcGIS for Developers
<SPAN class="comment token">// create portal with url and credential</SPAN> Credential<SPAN class="operator token">*</SPAN> cred <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">Credential</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"username"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"password"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> m_portal <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token function">Portal</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">QUrl</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Farcgis.com" target="_blank">https://arcgis.com</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> cred<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// connect to done loading</SPAN> <SPAN class="token function">connect</SPAN><SPAN class="punctuation token">(</SPAN>m_portal<SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">&</SPAN>Portal<SPAN class="operator token">::</SPAN>doneLoading<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">(</SPAN>Error e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">isEmpty</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">qDebug</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><<</SPAN> e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">message</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><<</SPAN> e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">additionalMessage</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="comment token">// connect to findItemsCompleted</SPAN> <SPAN class="token function">connect</SPAN><SPAN class="punctuation token">(</SPAN>m_portal<SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">&</SPAN>Portal<SPAN class="operator token">::</SPAN>findItemsCompleted<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">(</SPAN>PortalQueryResultSetForItems<SPAN class="operator token">*</SPAN> items<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// loop through results</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">int</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> items<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">itemResults</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">size</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">auto</SPAN> item <SPAN class="operator token">=</SPAN> items<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">itemResults</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">at</SPAN><SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// load the item</SPAN> <SPAN class="token function">connect</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">&</SPAN>PortalItem<SPAN class="operator token">::</SPAN>doneLoading<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN>item<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">(</SPAN>Error e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>e<SPAN class="punctuation token">.</SPAN><SPAN class="token function">isEmpty</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">qDebug</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><<</SPAN> item<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">name</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> item<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> PortalQueryParametersForItems queryParams<SPAN class="punctuation token">;</SPAN> queryParams<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setSearchString</SPAN><SPAN class="punctuation token">(</SPAN>R<SPAN class="string token">"(type:"</SPAN>map service<SPAN class="string token">")"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> m_portal<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">findItems</SPAN><SPAN class="punctuation token">(</SPAN>queryParams<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// load the portal</SPAN> m_portal<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN><SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi Luke, i would like to continue using V100.6 now:
In the meantime i was able do an OfflineMapTask using a webmap . So im in touch with the portal now.
But the authentication is still a black box, so i skipped that
(Credentials, authManager .. no idea, How i can verify, that openSSL ist working?)
I want to iterate over the items the portal is hosting, maybe list the map services, list the webmaps or similar.
So i tried, fetchBasemaps, fetchFeaturedGroups, fetchFeaturedItems, fetchHomepageFeaturedContent.
Perform some find operations, but no adequat result 😞
Most of the time empty lists, because the portal is nearly empty.
But only a few map services are discovered using the SDK, Is that limited to 10?
(I have ~75 Map Services, ~30 are shared. And shared is public to everyone on my portal)
Is there an sample which discovers an portal?
Has someone overcome the authentication (SDK) of an own portal?
One usecase shoudl be listing the Map Services and/or WebServices. And getting the thumbnail of the map would be the cherry on the cake 🙂
My portal has one user: portaladmin,
Since last week, there are only map services, nothing else.
If publishing a map services was successful, i shared that with everyone, no restictions!
No, portal, arcgisServer are in one network, the client in another. No idea how to change this...
