Generate geodatabase task only downloads the first feature class using this example:
https://github.com/Esri/arcgis-runtime-samples-qt/blob/master/ArcGISRuntimeSDKQt_QMLSamples/Features/GenerateGeodatabase/GenerateGeodatabase.qml
is this expected behavior?
Thank you,
I'm not seeing this behavior. Which version are you using? Are you in an area that only has the one layer visible in it? Here is my output which contains points, lines, and polygons:
Hey Lucas,
I am downloading the whole California and the Geodatabase only has points:
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
