I believe you need this infopopup widget for it to work. See attachment.Yas(h)ar
At the bottom of the SelectionWidget.xml there is an <info>widgets/InfoTemplates/InfoPopupWidget.swf</info> tag.Make sure it is set to the correct path to your .swf file (remember, it is CaSe sensitive).If that doesn't work, what does the rest of the error message say?R_
widgets/InfoPopup/InfoPopupWidget.swf
Here You are:[ATTACH=CONFIG]27926[/ATTACH][ATTACH=CONFIG]27927[/ATTACH]
Does anyone have explanations of the SelectionWidget.xml options available?
Does anyone have a compiled version that works with 3.6 or 3.7?
Thanks
Spero but i don't have
Inviato da iPhone
Il giorno 05/mar/2015, alle ore 15:16, Kummer Laszlo <geonet@esri.com> ha scritto:Selection Widget Updated Versionreply from Kummer Laszlo in ArcGIS Viewer for Flex - View the full discussionDoes anyone have a compiled version that works with 3.6 or 3.7? ThanksReply to this message by replying to this email, or go to the message on GeoNetStart a new discussion in ArcGIS Viewer for Flex by email or at GeoNetFollowing Selection Widget Updated Version in these streams: InboxThis email was sent by GeoNet because you are a registered user.You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
Hi. Are you referring to this widget?
Yes.
Il giorno 05/mar/2015, alle ore 16:41, Lefteris Koumis <geonet@esri.com> ha scritto:Selection Widget Updated Versionreply from Lefteris Koumis in ArcGIS Viewer for Flex - View the full discussionHi. Are you referring to this widget?https://community.esri.com/servlet/JiveServlet/downloadImage/2-463158-68645/pastedImage_0.pngReply to this message by replying to this email, or go to the message on GeoNetStart a new discussion in ArcGIS Viewer for Flex by email or at GeoNetFollowing Selection Widget Updated Version in these streams: InboxThis email was sent by GeoNet because you are a registered user.You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
Attached is compiled for 3.6.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
