<zoomscale>5000</zoomscale> <info>widgets/InfoTemplates/InfoPopupWidget.swf</info> </configuration>
Jefferson, The error you are getting means "Loaded file is an unknown type". I have seen this in the past when a widget is using the old infoPopup and someone mistakenly omits that line from the config xml for the widget. So do you have this line towards the bottom of your SelectionWidget.xml? <zoomscale>5000</zoomscale> <info>widgets/InfoTemplates/InfoPopupWidget.swf</info> </configuration>And if so are you sure that the widgets/InfoTemplates/InfoPopupWidget.mxml is added to the modules list of your flex viewer project so that it is being compiled to a swf?
Anyone have an idea about the error #2124?
Hey did you get to the bottom of this one?
Fantastic functionality added to FSV. Thanks for sharing this great tool.Is there anyway to have date values in the unique values box formated as dates, rather than the numbers that are actually stored?For example :<format dateformat="shortDate"/>ordateformat="MM/DD/YYYY"Thanks,Matt Shetzer
Marie, As you might have noticed this widget is no longer maintained. You would be better off using the eSearch that has about all the functionality that this widget has and more.
I am trying to get the selection outline color to match that of my eSearch widget. The coding is very similar, but does not seem to work correctly in the SelectionWidget.If I don't change it in the config.xml or hard code in the mxml, I get the default browinish color. If I change it in the config.xml or the mxml, it turns to a green color, no matter what I set it to (red, black, white, etc. always is the same green color). In the eSearch widget I set it to 0x00FFFF and get a nice light blue outline.Has anyone figured out how to make this change "take effect" in the SelectionWidget?Any ideas,R_
I do not get any errors. Just a few warnings about length not being bindable.R_
This is working for me. Not sure what all I've modified other than adding a help icon to the widget.R_
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
