Hi again Caroline,I think I might have solved my problem. When I was pulling in the url for the layer in the SelectionWidget.xml file, I was using the FeatureServer service instead of the MapServer service from my rest services directory. (The layer I am using is editible also.)When I tried using the MapServer url I got the unique values list to populate.Hopefully this fix will be as easy for you!Ashlee
Let me know if these updates workComplied with Date fix and:FLEX SDK 4.1 and AGS FLEX 2.5
Hello, I believe the issue of the unique fields not showing up is due to how the query works. I believe the field that you are having issues with is a non-string field. If that's the case and you are working with the uncompiled version:in utils/PagingQueryTask.as around line 184, you want to change query.text = "%" to query.where = "1=1"I'm almost positive that change is reflected in the versions with the date and time fix found here:http://forums.arcgis.com/threads/30179-Selection-Widget-Updated-Version?p=157653&viewfull=1#post157653http://forums.arcgis.com/threads/30179-Selection-Widget-Updated-Version?p=157654&viewfull=1#post157654http://forums.arcgis.com/threads/30179-Selection-Widget-Updated-Version?p=157756&viewfull=1#post157756Let me know if that fixes the issue
what is the exact issue you are facing
//New function private function removeGlow( fl:FeatureLayer ):void { var len:int = fl.numChildren; var dObj:DisplayObject; for ( var i:int = 0; i < len; i++ ) { dObj = fl.getChildAt( i ); if ( dObj.filters ) { dObj.filters = []; } } } //Updated function protected function featureLayer_selectionHandler(event:FeatureLayerEvent):void { removeGlow(event.featureLayer); dispatchEvent( new Event( 'featurelayer_selection', true ) ); var flEvent:SelectionFeatureLayerEvent = new SelectionFeatureLayerEvent( SelectionFeatureLayerEvent.LAYER_RESULTS,event.featureLayer); dispatchEvent(flEvent); if (event.type == FeatureLayerEvent.SELECTION_CLEAR) { this.showInfoWindow(null); } }
for (var i:int = 0; i < lyrList.length(); i++) { var lyrURL:String = lyrList.url; var lyrLabel:String = lyrList.name; var featureLayer:FeatureLayer = new FeatureLayer(lyrURL); featureLayer.name = lyrLabel; var l1lst:XMLList = (lyrList.maxscale as XMLList) var l2lst:XMLList = (lyrList.minscale as XMLList) //Override the min and max zoom scale if they are in the config // not sure why couldn't test directly but had to create varable first??? if (l1lst.length() > 0 ) featureLayer.maxScale = lyrList.maxscale; if (l2lst.length() > 0 ) featureLayer.minScale = lyrList.minscale; featureLayer.addEventListener(LayerEvent.LOAD, featureLayer_loadHandler); } ......... ........ ........ //ViewerContainer.dispatchEvent(new AppEvent(AppEvent.DATA_CREATE_INFOWIDGET, data, infoReady)); AppEvent.dispatch(AppEvent.DATA_CREATE_INFOWIDGET, data, infoReady);
I have updated this part of the init() function and it seems to be working fine in 3.0: Keep in mind that I am no pro by any means, but this seems to work. for (var i:int = 0; i < lyrList.length(); i++) { var lyrURL:String = lyrList.url; var lyrLabel:String = lyrList.name; var featureLayer:FeatureLayer = new FeatureLayer(lyrURL); featureLayer.name = lyrLabel; var l1lst:XMLList = (lyrList.maxscale as XMLList) var l2lst:XMLList = (lyrList.minscale as XMLList) //Override the min and max zoom scale if they are in the config // not sure why couldn't test directly but had to create varable first??? if (l1lst.length() > 0 ) featureLayer.maxScale = lyrList.maxscale; if (l2lst.length() > 0 ) featureLayer.minScale = lyrList.minscale; featureLayer.addEventListener(LayerEvent.LOAD, featureLayer_loadHandler); } ......... ........ ........ //ViewerContainer.dispatchEvent(new AppEvent(AppEvent.DATA_CREATE_INFOWIDGET, data, infoReady)); AppEvent.dispatch(AppEvent.DATA_CREATE_INFOWIDGET, data, infoReady); I still get a couple warnings about "Data binding will not be able to detect assignments to length" for the end of SelectByAttributes.mxml and SelectionResults.mxml but it is working.R_
I do not get any errors. Just a few warnings about length not being bindable.R_
