You select the raster you want to Clip/Mask in the Image Analysis window (IAW), from the list of rasters. You also select a polygon (feature class polygon), and then just hit the Clip or Mask button in the IAW. The layer is temporary by default.
Andrea,You can use the Mask button on the Image Analysis Window in ArcGIS 10. Image Analysis window: Processing sectionRegards,Eric
Don has the correct workflow. Use the clip under Data Management > Raster > Raster Processing. If you do not specify the input geometry, you will receive the bounding extents of the polygon. The output format of the raster is controlled by adding extensions. So .jpg for jpeg, .tif for tiff and so forth. The only limit is the raster to be output must have the band combination/bit depth for the desired format. Extract by Mask will also perform the clip, but Spatial Analyst is required.
Hello,
I'm fairly new to ArcMap, and I'm having the same problem clipping a raster. I've tried Clip in Raster Processing and Extract by Mask in Spatial Analyst tools.
I'm trying to clip the raster with a polygon. I thought of using Extract by Polygon, but it asks for coordinates as opposed to just selecting which polygon to use.
Either way, I would appreciate some help with this. Thanks in advance for your time.
You should be able to use the "Clip" tool in Raster Processing. After selecting the proper Input Raster (the raster you would like clipped), select the output extent (the shapefile or polygon you would like to use to clip your raster to). Next, make sure that the "Use Input Features for Clipping Geometry" box is checked.
That should give you a raster clipped to the same shape as your polygon.
