Hey gutys:
I want to find sample Reverse geocode | ArcGIS API for JavaScriptfor 4.8 than search[ lon, lat] to address(not click map to address).
but I didn't find this
So where can I go to find this
Ask for help
THANKS
Hsu,
Your code:
<SPAN class="keyword token">var</SPAN> pt <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>x<SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
was the way it was done in 3.x API. In the 4.x API you need to provide an object in the Point constructor that specifies the objects property names:
<SPAN class="keyword token">var</SPAN> pt <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>x<SPAN class="punctuation token">:</SPAN> x<SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">:</SPAN> y<SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
Here is an updated sample:
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"Content-Type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=utf-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Find Address<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.8%2Fesri%2Fcss%2Fmain.css" target="_blank">https://js.arcgis.com/4.8/esri/css/main.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body <SPAN class="punctuation token">{</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #map <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> border<SPAN class="punctuation token">:</SPAN> solid 2px #<SPAN class="number token">666</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN> 5px 5px 5px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #header <SPAN class="punctuation token">{</SPAN> border<SPAN class="punctuation token">:</SPAN> solid 2px #<SPAN class="number token">666</SPAN><SPAN class="punctuation token">;</SPAN> color<SPAN class="punctuation token">:</SPAN> #<SPAN class="number token">666</SPAN><SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>family<SPAN class="punctuation token">:</SPAN> sans<SPAN class="operator token">-</SPAN>serif<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN>1em<SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> auto<SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN> overflow<SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> 10px <SPAN class="number token">0</SPAN> 10px 20px<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>align<SPAN class="punctuation token">:</SPAN>left<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>roundedCorners <SPAN class="punctuation token">{</SPAN> <SPAN class="operator token">-</SPAN>webkit<SPAN class="operator token">-</SPAN>border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">-</SPAN>moz<SPAN class="operator token">-</SPAN>border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN> border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.8%2F" target="_blank">https://js.arcgis.com/4.8/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/Locator"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/support/webMercatorUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/PopupTemplate"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/number"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/parser"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/BorderContainer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/ContentPane"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> Locator<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> webMercatorUtils<SPAN class="punctuation token">,</SPAN> PopupTemplate<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">,</SPAN> number<SPAN class="punctuation token">,</SPAN> parser<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">,</SPAN> on <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"streets"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">118.3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">34.2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">11</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> locator <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Locator</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fgeocode.arcgis.com%2Farcgis%2Frest%2Fservices%2FWorld%2FGeocodeServer" target="_blank">https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PopupTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Location"</SPAN><SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Address: {Address}"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'btnGo'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'click'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> lon <SPAN class="operator token">=</SPAN> dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Lon'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> lat <SPAN class="operator token">=</SPAN> dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Lat'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> x <SPAN class="operator token">=</SPAN> <SPAN class="token function">parseFloat</SPAN><SPAN class="punctuation token">(</SPAN>lon<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> y <SPAN class="operator token">=</SPAN> <SPAN class="token function">parseFloat</SPAN><SPAN class="punctuation token">(</SPAN>lat<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> pt <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> x<SPAN class="punctuation token">:</SPAN> x<SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">:</SPAN> y<SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> locator<SPAN class="punctuation token">.</SPAN><SPAN class="token function">locationToAddress</SPAN><SPAN class="punctuation token">(</SPAN>pt<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">100</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> address <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>Address<SPAN class="punctuation token">:</SPAN> evt<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> location <SPAN class="operator token">=</SPAN> webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">geographicToWebMercator</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>location<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geometry<SPAN class="punctuation token">:</SPAN> location<SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-marker"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as new SimpleMarkerSymbol()</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"blue"</SPAN><SPAN class="punctuation token">,</SPAN> size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new SimpleLineSymbol()</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">,</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"darkblue"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> attributes<SPAN class="punctuation token">:</SPAN> address<SPAN class="punctuation token">,</SPAN> popupTemplate<SPAN class="punctuation token">:</SPAN> infoTemplate <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//display the info window with the address information</SPAN> view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">open</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> features<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>graphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> location<SPAN class="punctuation token">:</SPAN> location <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">webMercatorToGeographic</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> locator<SPAN class="punctuation token">.</SPAN><SPAN class="token function">locationToAddress</SPAN><SPAN class="punctuation token">(</SPAN>webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">webMercatorToGeographic</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">100</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> address <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>Address<SPAN class="punctuation token">:</SPAN> evt<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> location <SPAN class="operator token">=</SPAN> webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">geographicToWebMercator</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>location<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geometry<SPAN class="punctuation token">:</SPAN> location<SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-marker"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as new SimpleMarkerSymbol()</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"blue"</SPAN><SPAN class="punctuation token">,</SPAN> size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new SimpleLineSymbol()</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">,</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"darkblue"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> attributes<SPAN class="punctuation token">:</SPAN> address<SPAN class="punctuation token">,</SPAN> popupTemplate<SPAN class="punctuation token">:</SPAN> infoTemplate <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//display the info window with the address information</SPAN> view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">open</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> features<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>graphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> location<SPAN class="punctuation token">:</SPAN> location <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"claro"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"mainWindow"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/BorderContainer"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"design:'headline', gutters:false"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"width:100%; height:100%;"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"header"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"roundedCorners"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'top'"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>span<SPAN class="operator token">></SPAN>Click the map to <SPAN class="keyword token">get</SPAN> the address <SPAN class="keyword token">for</SPAN> the input location<SPAN class="punctuation token">.</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">'text'</SPAN> id<SPAN class="operator token">=</SPAN><SPAN class="string token">'Lat'</SPAN> value<SPAN class="operator token">=</SPAN><SPAN class="string token">"34.250812723611325"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>input<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">'text'</SPAN> id<SPAN class="operator token">=</SPAN><SPAN class="string token">'Lon'</SPAN> value<SPAN class="operator token">=</SPAN><SPAN class="string token">'-118.51732330322035'</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>input<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>button type<SPAN class="operator token">=</SPAN><SPAN class="string token">"button"</SPAN> id<SPAN class="operator token">=</SPAN><SPAN class="string token">'btnGo'</SPAN><SPAN class="operator token">></SPAN>Locate<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>button<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"roundedCorners"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'center'"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Here is the 3.x sample updated to 4.8:
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"Content-Type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=utf-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Find Address<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.8%2Fesri%2Fcss%2Fmain.css" target="_blank">https://js.arcgis.com/4.8/esri/css/main.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body <SPAN class="punctuation token">{</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #map <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> border<SPAN class="punctuation token">:</SPAN> solid 2px #<SPAN class="number token">666</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN> 5px 5px 5px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #header <SPAN class="punctuation token">{</SPAN> border<SPAN class="punctuation token">:</SPAN> solid 2px #<SPAN class="number token">666</SPAN><SPAN class="punctuation token">;</SPAN> color<SPAN class="punctuation token">:</SPAN> #<SPAN class="number token">666</SPAN><SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>family<SPAN class="punctuation token">:</SPAN> sans<SPAN class="operator token">-</SPAN>serif<SPAN class="punctuation token">;</SPAN> font<SPAN class="operator token">-</SPAN>size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN>1em<SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> auto<SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN> overflow<SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> 10px <SPAN class="number token">0</SPAN> 10px 20px<SPAN class="punctuation token">;</SPAN> text<SPAN class="operator token">-</SPAN>align<SPAN class="punctuation token">:</SPAN>left<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>roundedCorners <SPAN class="punctuation token">{</SPAN> <SPAN class="operator token">-</SPAN>webkit<SPAN class="operator token">-</SPAN>border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">-</SPAN>moz<SPAN class="operator token">-</SPAN>border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN> border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.8%2F" target="_blank">https://js.arcgis.com/4.8/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/Locator"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/support/webMercatorUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/PopupTemplate"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/number"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/parser"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/BorderContainer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/ContentPane"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> Locator<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> webMercatorUtils<SPAN class="punctuation token">,</SPAN> PopupTemplate<SPAN class="punctuation token">,</SPAN> number<SPAN class="punctuation token">,</SPAN> parser <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"streets"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">118.3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">34.2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">11</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> locator <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Locator</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fgeocode.arcgis.com%2Farcgis%2Frest%2Fservices%2FWorld%2FGeocodeServer" target="_blank">https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PopupTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Location"</SPAN><SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Address: {Address}"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> locator<SPAN class="punctuation token">.</SPAN><SPAN class="token function">locationToAddress</SPAN><SPAN class="punctuation token">(</SPAN>webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">webMercatorToGeographic</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">100</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> address <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>Address<SPAN class="punctuation token">:</SPAN> evt<SPAN class="punctuation token">.</SPAN>address<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> location <SPAN class="operator token">=</SPAN> webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">geographicToWebMercator</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>location<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geometry<SPAN class="punctuation token">:</SPAN> location<SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-marker"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as new SimpleMarkerSymbol()</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"blue"</SPAN><SPAN class="punctuation token">,</SPAN> size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new SimpleLineSymbol()</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">,</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"darkblue"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> attributes<SPAN class="punctuation token">:</SPAN> address<SPAN class="punctuation token">,</SPAN> popupTemplate<SPAN class="punctuation token">:</SPAN> infoTemplate <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//display the info window with the address information</SPAN> view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">open</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> features<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>graphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> location<SPAN class="punctuation token">:</SPAN> location <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"claro"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"mainWindow"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/BorderContainer"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"design:'headline', gutters:false"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"width:100%; height:100%;"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"header"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"roundedCorners"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'top'"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>span<SPAN class="operator token">></SPAN>Click the map to <SPAN class="keyword token">get</SPAN> the address <SPAN class="keyword token">for</SPAN> the input location<SPAN class="punctuation token">.</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"roundedCorners"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'center'"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Thanks
but I want "search[ lon, lat] to address(not click map to address)"
this my code:
var locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"); var x = parseFloat(lon); var y = parseFloat(lat); var pt = new Point(x, y, new SpatialReference({ wkid: 4326 }));
got error this :
Uncaught TypeError: c.indexOf is not a function at Object.m (dojo.js:315) at Object.set (dojo.js:228) at Object.postscript (dojo.js:227) at new <anonymous> (dojo.js:237) at Location.js?20161027:381 at K (dojo.js:18) at dojo.js:19 at E (dojo.js:19) at da (dojo.js:19) at e (dojo.js:21)
How can I do this ?
Thank your help
I have two questions.
1.
this my code.
var locator = new Locator("https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"); var x = parseFloat(-118.51732330322035); var y = parseFloat(34.250812723611325); var pt = new Point({ x: x, y: y, spatialReference: new SpatialReference({ wkid: 4326 }) });locator.locationToAddress(pt, 100).then(function(evt){ if (evt.address) { var address = {Address: evt.address};
get error this:
Uncaught TypeError: a.clone(...).normalize is not a function at Object.b.locationToAddress (Locator.js:8) at Location.js?20161027:388 at K (dojo.js:18) at dojo.js:19 at E (dojo.js:19) at da (dojo.js:19) at e (dojo.js:21) at HTMLScriptElement.<anonymous> (dojo.js:23)
What have I ignored?
2.The sample you provided
<SPAN class="" style="color: #0077aa; border: 0px; font-weight: inherit;">var</SPAN> address <SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit;">=</SPAN> <SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">{</SPAN>Address<SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">:</SPAN> evt<SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">.</SPAN>address<SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">}</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">;</SPAN>
I want to get "Match_addr" , but I can't Why? {"address":{"Match_addr":"17545 Lassen St, Northridge, California, 91325","LongLabel":"17545 Lassen St, Northridge, CA, 91325, USA","ShortLabel":"17545 Lassen St","Addr_type":"PointAddress","Type":"","PlaceName":"","AddNum":"17545","Address":"17545 Lassen St","Block":"","Sector":"","Neighborhood":"Northridge","District":"","City":"Northridge","MetroArea":"Los Angeles Metro Area","Subregion":"Los Angeles County","Region":"California","Territory":"","Postal":"91325","PostalExt":"","CountryCode":"USA"},"location":{"x":-118.51724250000001,"y":34.250362478792603,"spatialReference":{"wkid":4326,"latestWkid":4326}}}
You are telling the parseFloat function to parse a number (which make no sense). The parseFloat is for making a sting a number.
This would be correct:
var x = parseFloat('-118.51732330322035'); var y = parseFloat('34.250812723611325');
2. Because Match_addr is not part of the evt object it is part of the evt.attributes object:
var address = {Address: evt.attributes.Match_addr};
THANK Your Tips.
but I have the 1 same error again.
mycode:
require([ "esri/Map", "esri/views/MapView", "esri/widgets/Search", "esri/Graphic", "esri/geometry/Point", "esri/tasks/Locator", "esri/geometry/SpatialReference", "esri/PopupTemplate", "dojo/domReady!" ], function(Map, MapView, Search, Point, SpatialReference, Locator ) {
var locator = new Locator("https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"); var x = parseFloat('-118.51732330322035'); var y = parseFloat('34.250812723611325'); var pt = new Point({ x: x, y: y, spatialReference: new SpatialReference({ wkid: 4326 }) });locator.locationToAddress(pt, 100).then(function(evt){ if (evt.address) { var address = {Address: evt.address};
get error this.
Please help again.
Your requires are out of order:
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Search"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/Locator"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/PopupTemplate"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map MapView<SPAN class="punctuation token">,</SPAN> Search<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> Locator <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
it should be:
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Search"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/Locator"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/PopupTemplate"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map MapView<SPAN class="punctuation token">,</SPAN> Search<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">,</SPAN> Locator<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> PopupTemplate <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Notice, line 2 = line 13, 3 = 13, etc, etc
Thank your help.
My other two questions.1. There is something wrong with the address returned by location. If I want to provide information and ask you to modify it.What should I do?Because some locations return the store name, it is not the address of the return details.2.google api "timezone", is there a way to convert?
Hi
1.YES.Some time return not correct address,return Commercial store name
So how can I do?
2.For your reference↓
Developer Guide | Time Zone API | Google Developers
I focus this↓
the offset for daylight-savings time in seconds. This will be zero if the time zone is not in Daylight Savings Time during the specified timestamp.
timestamp
2. Sorry I don't use the Google maps API so I can't help there.
Robert,
1.Again anwser YES,Not the same value returned by google.
You can compare the latitude and longitude of a commercial vending shop.
2.Then, if you get the information obtained abroad, how to solve the time zone offset?
Can you provide an example of when a lat long returns a store name instead of an address? Example lat lon.
HI,Robert.
Try this example:
x:24.979867y:121.549301
and then I got the new question.
circle = new Circle({ center: [lng,lat], geodesic: false, radius: 300, // 300 feet radiusUnit: "meters" }); view.graphics.add({ symbol: { type: "simple-marker", color: [255,0,0,0.25], size:1000 }, geometry:circle }); <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
symbol 's size and circle's radius,Which is the main influence on drawing information?
because I not set symbol 's size ,not draw circle
