They have augmented the 'Create Tin' tool to do all of the processing like the old toolbar button did. The old 'Create TIN' did not include data, but the new one does. I agree the help needs to be updated for version 10 and I have indicated as much on the feedback for the page. If you see something like that I encourage using that feedback button. It is a little button with a pencil on it. As far as the TIN Chris mentioned, it appears that you are using your boundary as a Hard Clip rather than Soft clip. I would create the TIN again and this time, specify a soft clip and remove the height for that feature.
I'm wondering why ESRI couldn't includes all the commands in the ArcToolbox. It's quite crucial for the user to access all the commands from one place!
second, some times, the same command has two different names! one name in the Arctoolbox and other name in the toolbar minue!
All of the commands have always been in ArcToolbox. The toolbar was what was limited in functionality. It only contained a subset of tools that 3D Analyst offered.This is one of the very reasons the toolbars from Spatial Analyst and 3D Analyst had their tools removed. Different names, different parameters, different UI's, different environments/options, all led to confusion for many users. The full power of these extensions (analytically anyway) has always been and remains in ArcToolbox.Regards,Eric
Hi Jamal,Please provide specific examples and I can provide comments/history.Thanks,Eric
Hi Jamal,I was hoping to keep this specific to either 3D or Spatial Analyst, but I'll run with what you've provided. The Export Data dialog has several equivalent geoprocessing tools. Because of this, it can't have the exact same name as a single tool in ArcToolbox. The raster > Data > Export Data dialog provides the following capabilities.Converting your input raster to another formatProjecting your raster to another coordinate systemChanging the cell size of your rasterClipping a raster datasetSub setting a raster dataset with more than 3 bands, so that you just get the 3 bands being displayed. e.g. Converting 7 band landsat to 3 band landsatPermanently applying a stretch to an image (No single equivalent GP tool because it needs the renderer information to do this.)In ArcToolbox you would use these tools to mimic the Export Raster Data dialog.Copy RasterProject RasterResampleClipComposite BandsMake Raster LayerThe export dialog is more of an interactive user experience and while GP can be run from the Desktop, it is often run via scripting. There is no way we would make a single GP tool with all of the possible parameters that could be called from the export dialog. Regards,Eric
Hi Jamal,I think you have legitimate points with these two examples although we've deviated quite a bit from anything to do with the deprecation of the 3d toolbar tools. I discussed this thread with the User Advocacy Group and highlighted a number of your concerns/examples. They will be sure to discuss with the respective teams involved. My guess at what happened is the Explode UI command was in the software, then at some later date there was a need to automate the functionality, and another team created the GP tool and named it something different than the UI command. Just my hunch. Nonetheless, I see how it can create confusion.The Planarize Lines command does actually have some GP tools that do the same. For example, Feature to Line can be used to split the lines at intersections. Depending on whether or not you preserve attributes you will retain the overlapping line segments (preserving keeps overlap). There is also a simple model that could be built that would incorporate Intersect (output type points), Split Line at Point, and Delete Identical (using Shape field). Feature to Line works on more than just line input which is probably why it's not called Planarize Lines event though it can do the same thing. At the very least, searching on the word Planarize should return better results. I will submit a NIM to the team so that additional tags are added to the Feature to Line tool for search purposes.Thanks for your feedback.Best,Eric
[ATTACH=CONFIG]29773[/ATTACH]I realize this is a long dead thread, but for those of you who still might be interested:"Create TIN from Features" is still available in its original form and under it's original name if you add it to the 3D Analyst toolbar using customize, commands tab, 3D Analyst, then drag and drop the "Create TIN From Features" button onto your 3D Analyst toolbar. Here's my question, how do I use Create TIN From Features in Modelbuilder?Thanks, Belle
