class Result(object): def __init__(self, status, inputs, outputs, messages): """Initializes the result. ARGUMENT DESCRIPTION -------- ----------- status The job status. inputs The inputs to the job. outputs The outputs of the job. messages The messages of the job represented as a list of tuples whose values are (severity, message). STATUS DESCRIPTION ------ ----------- 0 New 1 Submitted 2 Waiting 3 Executing 4 Succeeded 5 Failed 6 Timed Out 7 Cancelling 8 Cancelled 9 Deleting 10 Deleted SEVERITY DESCRIPTION -------- ----------- 0 Informational Message 1 Warning Message 2 Error Message """ self._status = status """The job status. STATUS DESCRIPTION ------ ----------- 0 New 1 Submitted 2 Waiting 3 Executing 4 Succeeded 5 Failed 6 Timed Out 7 Cancelling 8 Cancelled 9 Deleting 10 Deleted """ self._inputs = inputs """The inputs to the job.""" self._outputs = outputs """The outputs of the job.""" self._messages = messages """The messages of the job represented as a list of tuples whose values are (severity, message). SEVERITY DESCRIPTION -------- ----------- 0 Informational Message 1 Warning Message 2 Error Message """ @classmethod def from_arcpy_result(cls, result): """Creates a Result from an arcpy.Result instance. ARGUMENT DESCRIPTION -------- ----------- result An instance of arcpy.Result. """ assert isinstance(result, arcpy.Result), ( "Result %r is not an instance of arcpy.Result." % result) status = result.status inputs = [result.getInput(i) for i in range(result.inputCount)] outputs = [result.getOutput(i) for i in range(result.outputCount)] messages = [] for i in range(result.messageCount): messages.append((result.getSeverity(i), result.getMessage(i))) return cls(status, inputs, outputs, messages) @property def inputCount(self): """The number of inputs of the job.""" return len(self._inputs) @property def maxSeverity(self): """The maximum severity of the messages. SEVERITY DESCRIPTION -------- ----------- 0 Informational Message 1 Warning Message 2 Error Message """ return max([severity for severity, message in self._messages]) @property def messageCount(self): """The number of messages.""" return len(self._messages) @property def outputCount(self): """The number of outputs.""" return len(self._outputs) @property def resultID(self): """The job ID if the tool is a geoprocessing service, else "".""" return self._resultID @property def status(self): """The job status. STATUS DESCRIPTION ------ ----------- 0 New 1 Submitted 2 Waiting 3 Executing 4 Succeeded 5 Failed 6 Timed Out 7 Cancelling 8 Cancelled 9 Deleting 10 Deleted """ return self._status def cancel(self): """Cancels the job.""" pass def getInput(self, index): """Returns the input at the given index, either as a record set or a string. ARGUMENT DESCRIPTION -------- ----------- index Index of the input to return. """ return self._inputs[index] def getMapImageURL(self, *args, **kwargs): """Returns a map service image for a given output, if one exists.""" raise NotImplementedError def getMessage(self, index): """Returns the message at the given index. ARGUMENT DESCRIPTION -------- ----------- index Index of the message to return. """ return self._messages[index] def getMessages(self, severity=0): """Returns messages of the given severity or greater. SEVERITY DESCRIPTION -------- ----------- 0 Informational Message 1 Warning Message 2 Error Message """ messages = [] for s, m in self._messages: if s >= severity: messages.append(m) return "\n".join(messages) def getOutput(self, index): """Returns the output at the given index, either as a record set or a string. ARGUMENT DESCRIPTION -------- ----------- index Index of the output to return. """ return self._outputs[index] def getSeverity(self, index): """"Returns the severity of the message at the given index. SEVERITY DESCRIPTION -------- ----------- 0 Informational Message 1 Warning Message 2 Error Message """ return self._messages[index][0]
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
