Charles:In your python script, could you add code to output a "dissolved" new featureclass of your selected counties for an "outline" shape that represents all counties being considered?
Charles:Please see this Esri Online Help for the Dissolve tool:http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000005n000000If all your counties of interest have a common attribute in an attribute field, you can "dissolve" on the field/attribute and create a new featureclass.
The dissolve tool may not be recognizing the joined field as a legitimate field to perform the task. Perform the join to csv and then create a new featureclass and then perform the dissolve on that new featureclass.
Try the Copy Features (Data Management) tool.http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001700000035000000import arcpyfrom arcpy import envenv.workspace = "C:/data"arcpy.CopyFeatures_management("InFeature.shp", "C:/output/output.gdb/OutFeature")
