Hello,
I have added a field to feature layer hosted on arcgis online using the agol add field button. This field does not appear on collector despite setting it to be editable.
is this a known bug?
Did you check the map's pop-up display settings? You may need to check the display and edit boxes as this may not be automatic when adding a new field.
Hey Randy,
Thanks for the response. I did check this setting in order to make it editable.
And the box for visible is also checked?
yup
And the Collector map was refreshed?
yes it was
Puzzling. And the map works as expected on AGOL? Is the field name unusual, a reserved SQL word or something?
Yes it works in AGOL. The field name is License so I don't think that should mess it up.
