Hello,
I have added a field to feature layer hosted on arcgis online using the agol add field button. This field does not appear on collector despite setting it to be editable.
is this a known bug?
Did you check the map's pop-up display settings? You may need to check the display and edit boxes as this may not be automatic when adding a new field.
Hey Randy,
Thanks for the response. I did check this setting in order to make it editable.
And the box for visible is also checked?
yup
And the Collector map was refreshed?
