hello all,
Does anyone try to use insight for ArcGIS? and is there any problem facing you when you try to use it??
is there any issue list address in insight for ArcGIS?? please, I need help on this topics .
You can Get Started with FAQs and Insightful Tips.
Ruba,
You may want to rename your question to something that is a little more specific like "Anyone have experience and advice installing Insight" or something similar. It will help others in the future to know this thread is about Insight. You can edit the title using the Edit button (upper right). It may look like you can not modify it, but if you click in the title it will let you. If you have troubles, one of us can help. thanks.
Thank you, Rebecca but I tried to make the modification on the title but it didn't work, however, i tried to install the insight but did not work with me. did you face a problem like this??
Thank you, Jayanta but the web app did not work with me. I do not know why??
We would need more details.
At what stage of installation is the issue coming up? Could you attach a screenshot of the error message, if any?
Check the installation prerequisites in Install Insights on Windows—ArcGIS Help | ArcGIS Enterprise and
also check Configure the portal to support Insights—ArcGIS Help | ArcGIS Enterprise
Please avoid use of the word "urgent", especially in titles, since all it really does is drive away potential respondents.
Hi Ruba,
FYI, Insights for ArcGIS is designed and meant to work with Portal for ArcGIS 10.5 configured with a hosting server.
Are you trying to deploy it with Portal for ArcGIS 10.5 PreRelease? or are you trying to deploy it with an earlier release of Portal for ArcGIS?
FYI 2: 10.5 final should be available very soon.
Hope this helps,
actually, I do not have the issue in installation but when I try to click the button of start new workbook it did not give you any result, just stay in the window, there is no action or any error
I take all requirements installation before I installed the insight
and when I'm in the first window of insight>> start workbook>> right click on the page>> Inspect>> Give me the following error :
I'm sorry for the confusion, I tried to edit the title but unfortunately, it did not work with me
Ruba, I modified the title for you, based on you comments about the problem.
Hi, Ruba
Did you check that the Insights installation file .exe has been installed on all machines in your distributed environment? The error you describe here is similar to what happens if the insights installation component is installed correctly on the portal machine C:\Program Files\ArcGIS\Portal\apps
but missing on the machine with the ArcGIS server C:\Program Files\ArcGIS\Server
/Klaus
Just Finished installing Insights 1.2.1 and stumbled into this problem, when I click on the "Create new workbook" button the javascript tries a request to the machine name, instead of the public domain where I installed and configured everything, and gets blocked by a certificate violation.
Everything has been setup according to the requirements and working fine, except Insights.
Any idea?
A few things to try:
Dara
Hello, this was a clean installation on a Single Machine (server, portal and datastore are all on the same machine and working fine)
I have installed using the 10.5 cookbook and chef, then installed Insights (which does not have anything particular to configure)
I double-checked the certificates, web adaptors and portal/server configurations and everywhere I find the correct url, in fact I can freely use everything, up to the Web Application Builder, except the "Create New Workbook" on Insights which still refers to the phisical machine instead of the public domain.
I tried un-minifying the javascript and debug this problem to find who or what uses the wrong address but it's not an easy task and I wasn't able to discover anything useful
Thank you for your answer, kind regards
Update: the problem seems to be related to the data store, in fact trying to host a vector tile package result in the same error, looks like the internal communication between portal/server and the data store is failing on the local address.
I wonder what is the correct approach for the SSL certificate, I have another machine with the 10.4 installed and this kind of problem are nowhere to be found, Is someone using the 10.5 data store on a public url without problems?
