I am trying to set-up link section of the header controller so that when I click on it, it opens the about widget(in panel) which contains help file on how to use the application. I would appreciate any help.
Anish,
Sure here is some code for that. This is code for the HeaderController Widget.js file:
Line 11 has to match the lebel of your link you want to open the help from.
Line 38 has to be the exact id of the about widget in your app (check the main config.json for this)
_createDynamicLinks<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>links<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>window<SPAN class="punctuation token">.</SPAN>isRTL<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> _links <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>links<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> _links<SPAN class="punctuation token">.</SPAN><SPAN class="token function">unshift</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> links <SPAN class="operator token">=</SPAN> _links<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">empty</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>dynamicLinksNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>links<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">===</SPAN> <SPAN class="string token">"Need Help? Click Here"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'a'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> href<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'#'</SPAN><SPAN class="punctuation token">,</SPAN> target<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'_self'</SPAN><SPAN class="punctuation token">,</SPAN> innerHTML<SPAN class="punctuation token">:</SPAN> utils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">sanitizeHTML</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">.</SPAN>label<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> click<SPAN class="punctuation token">:</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>showHelp<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'class'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"jimu-link jimu-align-leading jimu-leading-margin1"</SPAN><SPAN class="punctuation token">,</SPAN> style<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> lineHeight<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>height <SPAN class="operator token">+</SPAN> <SPAN class="string token">'px'</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>dynamicLinksNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN> html<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'a'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> href<SPAN class="punctuation token">:</SPAN> link<SPAN class="punctuation token">.</SPAN>url<SPAN class="punctuation token">,</SPAN> target<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'_blank'</SPAN><SPAN class="punctuation token">,</SPAN> rel<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'noopener noreferrer'</SPAN><SPAN class="punctuation token">,</SPAN> innerHTML<SPAN class="punctuation token">:</SPAN> utils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">sanitizeHTML</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">.</SPAN>label<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'class'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"jimu-link jimu-align-leading jimu-leading-margin1"</SPAN><SPAN class="punctuation token">,</SPAN> style<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> lineHeight<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>height <SPAN class="operator token">+</SPAN> <SPAN class="string token">'px'</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>dynamicLinksNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> showHelp<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> config <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">getConfigById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"widgets_About_Widget_47"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">_showIconContent</SPAN><SPAN class="punctuation token">(</SPAN>config<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks Robert. It worked great !!!
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
