Trying to run an .exe (VS2010), from SQLServer 2005 DB as a SQL job. SQL DB is on x86 machine (Server 2003), .exe is on x64 (Server 2008 R2)machine, as is all ArcGIS software, license manager, etc.
On which machine is the .exe executing? Note that I am not asking where it physically is but rather on which machine is it running on. Sounds like it is running on the x86 machine and that machine does not have the ESRI bits installed. It won't use the assemblies on the 64 bit machine unless the .exe is executing on that machine.
I did modify the reference paths in the .exe to use a universal naming convention so it should be able to access the .dlls on the other server, I would think.
Right now we have a separate DB group who manages the majority of the City's databases. Then we have our SDE databases. What the overall intent is, is to have the SDE databases on our own SQL Server instance apart from an instance that currently has not only our databases, but other databases in the same instance of SQL Server.In addition, the idea was to also separate out the license manager and all ArcSDE components to its own server, separate from the database server.I don't view any of that being an issue as ESRI supports the separation of ArcSDE from SQL. However, what I am trying to trouble shoot is all the peripheral montage that comes with it. Prior to our separation (or if you would like, still currently in production) are numerous SQL jobs that we run on a nightly, weekly, and monthly basis. These jobs can include SSIS packages, .exes, and python scripts. The idea was to take these "GIS-oriented" pieces and put them on the ArcSDE server (not the database server), so everything is in one (a GIS Server/non-database) location and let the jobs continue to run, but call the .exes from a different location. It seems to work just fine (on other .exes) until I get to the "GIS" executables.This is the direction management wanted to head, so I get to figure it out.....I did modify the reference paths in the .exe to use a universal naming convention so it should be able to access the .dlls on the other server, I would think. Still at a loss.....it almost seems like something very small.....
