Is it possible to use addFeatures with MultiPolygon geometry? I'm using JS API 4.10 and I'm trying to change the geometry to Polygon. Is this right way do it or is there another way? Example is appreciated.
Br,
Markus
Hi Markus Åfelt,
Why would multipolygons not be supported by the ArcGIS REST API?
In the example below I will add a multipolygon to a Hosted Feature Layer - with some screen captures to show the result.
Is this helpful to you?
Egge-Jan
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"attributes"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"DESCRIPTION"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Test case multipolygon"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"geometry"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"rings"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">155000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">463000</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">156000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">463000</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">156000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">464000</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">155000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">464000</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">155000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">463000</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">157000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">463000</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">158000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">463000</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">158000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">464000</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">157000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">464000</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">157000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">463000</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Can you please elaborate your question a little more? What are you trying to do? What does your code look like? Does it work, or do you get any error messages?
With some more information from your side, the community might be able to provide examples.
TIA,
I am trying to use addFeatures functionality from Arcgis rest api. Multipolygon is not supported in Arcgis rest api nor Arcgis JS API so I tried to converted multipolygon to polygon using Arcgis JS API
here is my geometry:
return geom.coordinates.map(c => new Polygon({ rings: c, spatialReference: { wkid: 3067 }, }));
Arcgis rest api addFeature will receive this kind of request
[{"attributes":{"example":78.7267},"geometry":[{"spatialReference":{"wkid":3067},"rings":[[[574679.425,7202092.787],[574794.358,7202076.863],[574843.167,7202069.869],[574876.487,7202090.896],[574910.799,7202085.747],[575164.385,7202050.636],[575294.996,7202032.568],[575509.807,7202002.822],[575528.746,7201990.488],[575687.094,7201968.255],[575708.413,7201975.09],[575851.112,7201955.619],[576024.742,7201931.503],[576044.047,7201922.232],[576202.623,7201899.972],[576222.949,7201904.297],[576517.42,7201863.518],[576617.829,7201847.344],[576714.165,7201825.039],[576808.544,7201796.49],[576901.429,7201761.914],[576991.568,7201720.448],[577007.381,7201707.462],[577263.109,7201581.157],[577518.836,7201454.853],[577774.565,7201328.547],[577878.774,7201272.812],[577962.785,7201220.762],[578042.586,7201163.263],[578061.104,7201155.162],[578063.723,7201152.615],[578150.849,7201077.011],[578378.244,7200866.382],[578405.9,7200840.865],[578483.015,7200772.747],[578493.939,7200754.438],[578590.69,7200680.882],[578694.108,7200616.343],[578800.831,7200560.548],[578913.203,7200514.011],[578949.869,7200500.002],[578971.714,7200499.603],[579216.305,7200407.236],[579233.579,7200395.289],[579420.386,7200324.847],[579441.096,7200322.933],[579665.645,7200238.464],[579890.194,7200153.996],[580113.897,7200069.881],[580114.754,7200069.558],[580338.836,7199985.277],[580355.72,7199972.643],[580365.479,7199968.7],[580434.567,7199942.689],[580435.35,7199942.395],[580586.159,7199885.619],[580617.325,7199873.884],[580637.57,7199871.43],[580714.436,7199842.803],[580733.288,7199808.596],[580804.049,7199782.412],[580927.654,7199735.656],[581064.01,7199672.748],[581075.912,7199667.256],[581157.766,7199629.492],[581193.239,7199609.878],[581248.867,7199579.531],[581286.632,7199587.075],[581415.07,7199516.416],[581493.438,7199474.386],[581607.797,7199431.025],[581726.714,7199405.534],[581848.412,7199397.648],[581970.338,7199407.644],[582022.882,7199420.98],[582088.599,7199437.207],[582223.996,7199482.844],[582228.86,7199468.911],[582511.86,7199565.399],[582512.167,7199565.503],[582781.782,7199656.656],[582987.088,7199726.431],[583013.223,7199750.068],[583133.896,7199792.204],[583247.293,7199826.416],[583363.049,7199843.47],[583480.58,7199841.154],[583597.097,7199823.042],[583632.399,7199811.011],[583708.882,7199785.484],[583744.445,7199769.778],[583784.558,7199751.489],[583800.633,7199738.521],[583946.234,7199672.644],[583966.187,7199669.105],[584166.929,7199578.45],[584183.979,7199567.495],[584412.512,7199464.125],[584648.005,7199357.606],[584753.971,7199304.938],[584773.518,7199292.356],[584853.585,7199241.695],[584966.64,7199161.237],[584984.564,7199152.286],[585066.274,7199094.128],[585077.945,7199075.961],[585289.633,7198925.468],[585310.59,7198920.196],[585407.858,7198850.667],[585422.474,7198836.713],[585585.378,7198720.731],[585603.526,7198711.763],[585716.481,7198631.515],[585815.404,7198561.236],[585916.147,7198494.249],[586022.759,7198436.604],[586134.24,7198389.037],[586191.111,7198368.284],[586200.424,7198364.229],[586258.301,7198346.705],[586268.492,7198345.014],[586342.89,7198327.604],[586544.048,7198281.825],[586544.167,7198281.798],[586794.311,7198224.87],[586902.382,7198198.227],[587013.467,7198156.227],[587118.155,7198102.776],[587330.396,7197982.061],[587549.936,7197857.191],[587547.98,7197851.103],[587552.32,7197850.328],[587568.115,7197847.072],[587676.929,7197785.528],[587990.982,7197606.335],[588004.885,7197594.113],[588057.065,7197564.792],[588065.749,7197559.865],[588279.636,7197438.514],[588298.593,7197430.966],[588471.93,7197332.242],[588621.029,7197247.504],[588693.281,7197209.669],[588770.736,7197184.534],[588773.817,7197018.47],[588912.313,7197020.832],[588980.8,7197065.614],[589003.99,7197075.543],[589028.569,7197086.107],[589123.688,7197120.78],[589168.956,7197131.453],[589183.315,7197135.289],[589222.069,7197138.923],[589350.397,7197141.355],[589494.7,7197144.469],[589494.656,7197146.29],[589493.596,7197189.34],[589560.362,7197190.7],[589561.835,7197145.774],[589565.153,7197145.895],[589572.15,7197146.036],[589619.263,7197148.54],[589737.699,7197151.097],[589752.768,7197153.482],[589837.363,7197151.165],[589950.336,7197156.99],[589993.432,7197159.454],[589984.372,7197189.986],[590000.165,7197190.279],[590034.119,7197199.296],[590003.052,7197226.205],[589935.04,7197278.296],[589930.28,7197281.943],[589953.954,7197303.593],[589941.1,7197303.938],[589920.887,7197281.231],[589880.23,7197308.053],[589862.043,7197321.808],[589847.409,7197321.47],[589777.44,7197319.856],[589747.98,7197319.12],[589712.494,7197318.452],[589672.551,7197317.867],[589642.932,7197317.372],[589612.479,7197317.046],[589581.654,7197316.176],[589545.973,7197315.631],[589504.775,7197314.952],[589472.934,7197314.337],[589410.377,7197313.228],[589391.235,7197312.912],[589291.814,7197311.217],[589286.511,7197297.027],[589261.343,7197296.499],[589063.891,7197293.547],[589064.735,7197215.534],[589064.814,7197208.08],[588852.948,7197204.185],[588777.179,7197213.812],[588704.91,7197237.2],[588635.583,7197273.449],[588486.775,7197357.963],[588427.267,7197391.615],[588353.583,7197433.419],[588347.825,7197436.992],[588312.989,7197456.316],[588297.344,7197469.647],[588078.147,7197593.958],[588024.276,7197624.496],[588005.501,7197631.888],[587730.394,7197788.065],[587662.755,7197827.198],[587559.263,7197886.226],[587418.202,7197966.559],[587270.601,7198050.615],[587134.899,7198127.929],[587026.653,7198182.545],[586911.667,7198226.191],[586801.032,7198253.99],[586546.37,7198312.103],[586545.674,7198312.262],[586349.624,7198357.001],[586349.448,7198357.041],[586276.547,7198373.675],[586266.823,7198377.562],[586210.885,7198394.326],[586200.468,7198396.809],[586144.607,7198416.691],[586035.845,7198463.3],[585931.22,7198519.716],[585832.426,7198585.449],[585627.579,7198731.276],[585624.914,7198758.938],[585603.952,7198776.571],[585587.998,7198763.07],[585443.323,7198866.046],[585425.249,7198875.083],[585352.089,7198927.251],[585340.542,7198945.485],[585104.235,7199113.648],[585083.788,7199118.351],[585001.901,7199176.754],[584987.608,7199190.738],[584874.492,7199271.027],[584812.004,7199313.201],[584771.217,7199336.489],[584662.691,7199390.227],[584421.273,7199499.421],[584198.396,7199600.229],[584179.105,7199605.81],[583978.753,7199696.158],[583962.88,7199709.064],[583817.356,7199774.782],[583797.069,7199778.787],[583720.93,7199812.813],[583701.536,7199848.476],[583667.711,7199830.789],[583604.613,7199851.853],[583484.196,7199870.823],[583360.974,7199873.323],[583240.357,7199855.796],[583123.909,7199820.428],[582970.145,7199769.261],[582969.828,7199769.155],[582799.657,7199712.528],[582734.765,7199690.453],[582705.574,7199680.497],[582595.943,7199638.579],[582366.353,7199560.541],[582364.845,7199565.05],[582213.924,7199513.377],[582211.407,7199520.593],[582095.129,7199480.191],[582079.326,7199464.941],[582015.611,7199449.985],[581965.215,7199438.155],[581925.147,7199434.799],[581848.413,7199428.371],[581778.44,7199432.92],[581730.372,7199436.046],[581616.107,7199460.254],[581507.005,7199502.035],[581493.164,7199516.887],[581433.345,7199548.919],[581305.405,7199619.994],[581287.138,7199648.97],[581196.745,7199699.579],[580954.027,7199811.205],[580761.337,7199883.918],[580725.104,7199870.636],[580648.14,7199899.493],[580631.166,7199910.939],[580419.195,7199991.495],[580369.198,7200009.989],[580349.06,7200012.383],[580124.688,7200096.819],[580124.595,7200096.854],[579900.316,7200181.255],[579675.944,7200265.689],[579451.573,7200350.126],[579434.697,7200362.037],[579247.305,7200432.979],[579226.755,7200435.216],[578982.019,7200527.586],[578965.99,7200540.631],[578928.633,7200555.214],[578819.388,7200600.787],[578715.856,7200654.493],[578615.391,7200717.288],[578521.05,7200788.673],[578502.151,7200795.828],[578426.358,7200862.984],[578376.081,7200909.475],[578171.37,7201098.945],[578079.942,7201178.281],[578066.954,7201195.146],[577985.041,7201253.94],[577899.396,7201307.665],[577792.06,7201364.741],[577772.142,7201368.633],[577544.878,7201480.899],[577317.615,7201593.164],[577090.351,7201705.429],[577004.137,7201747.681],[576912.893,7201789.256],[576818.633,7201824.893],[576722.727,7201853.821],[576623.641,7201876.714],[576521.11,7201893.271],[576227.309,7201933.909],[576208.299,7201943.197],[576051.431,7201964.826],[576029.493,7201961.325],[575852.992,7201985.647],[575692.835,7202007.673],[575674.379,7202020.248],[575535.746,7202039.637],[575514.328,7202032.748],[575301.348,7202061.967],[575177.228,7202079.354],[574880.986,7202120.163],[574854.082,7202148.988],[574693.432,7202173.131],[574549.179,7202191.132],[574505.416,7202176.294],[574401.984,7202172.866],[574320.263,7202153.469],[574245.326,7202115.621],[574179.149,7202064.637],[574125.52,7202001.373],[574084.629,7201928.339],[574062.081,7201861.711],[574042.731,7201856.692],[574091.275,7201780.143],[574097.269,7201839.864],[574120.752,7201912.695],[574157.774,7201979.005],[574207.463,7202036.371],[574267.062,7202082.243],[574334.685,7202116.193],[574396.919,7202132.25],[574679.425,7202092.787]],[[589795.955,7197287.157],[589796.813,7197228.289],[589899.247,7197224.599],[589907.023,7197259.668],[589866.896,7197292.62],[589795.955,7197287.157]]]}]}]
but I will receive error code:
{ "error": { "code": 400, "message": "Unable to complete operation.", "details": [ ] } }
Something wrong with your request. "geometry" shouldn't be array. See
documentation
https://developers.arcgis.com/rest/services-reference/apply-edits-feature-service-.htm
for samples.
Yes, its because of
return geom.coordinates.map(c => new Polygon({rings: c,spatialReference: { wkid: 3067 },}));
but looks like it is impossible? to convert multipolygon to polygon? so AddFeatures would accept it...
And still be valid data.
Thanks for the example, I will check it out.
I just checked from data types documentation and it was missing in here?
Geometry objects—Common Data Types | ArcGIS for Developers
or was I looking from wrong place?
Hmm, still problems... too many arrays inside of each other?
[{"attributes":{"example":32.9089},"geometry":{"rings":[[[[384581.523,6674356.23],[384619.235,6674288.869],[384622.269,6674293.37],[384630.611,6674304.771],[384660.424,6674340.894],[384675.344,6674356.931],[384675.754,6674357.524],[384675.978,6674358.21],[384675.996,6674358.931],[384675.807,6674359.627],[384675.428,6674360.241],[384674.889,6674360.721],[384674.235,6674361.026],[384673.522,6674361.133],[384668.36,6674361.147],[384581.523,6674356.23]]],[[[385238.873,6673600.771],[385241.519,6673602.643],[385245.086,6673605.427],[385248.374,6673608.536],[385251.355,6673611.941],[385254.002,6673615.611],[385256.292,6673619.514],[385258.204,6673623.616],[385259.72,6673627.879],[385260.829,6673632.267],[385265.777,6673658.669],[385266.136,6673660.633],[385266.353,6673662.765],[385266.319,6673664.853],[385266.101,6673666.723],[385265.682,6673668.573],[385265.133,6673670.325],[385264.287,6673672.238],[385263.144,6673674.238],[385262.011,6673675.807],[385258.256,6673679.776],[385254.429,6673683.682],[385249.029,6673688.439],[385232.125,6673701.726],[385211.295,6673718.29],[385190.938,6673734.983],[385188.536,6673736.437],[385186.016,6673737.675],[385183.397,6673738.687],[385180.699,6673739.466],[385177.944,6673740.005],[385175.152,6673740.3],[385172.344,6673740.35],[385169.543,6673740.152],[385120.163,6673732.628],[385142.622,6673585.167],[385142.842,6673583.998],[385143.143,6673582.848],[385143.524,6673581.722],[385143.982,6673580.626],[385144.516,6673579.564],[385145.123,6673578.542],[385145.8,6673577.565],[385146.543,6673576.638],[385148.16,6673574.998],[385149.984,6673573.592],[385151.981,6673572.446],[385154.115,6673571.58],[385156.346,6673571.011],[385158.634,6673570.748],[385160.936,6673570.797],[385163.211,6673571.157],[385178.047,6673574.548],[385181.041,6673575.269],[385184.017,6673576.06],[385186.974,6673576.922],[385189.91,6673577.852],[385192.823,6673578.852],[385195.712,6673579.919],[385198.575,6673581.054],[385201.41,6673582.257],[385222.29,6673591.401],[385224.462,6673592.385],[385226.609,6673593.425],[385228.728,6673594.518],[385230.819,6673595.665],[385232.881,6673596.864],[385234.911,6673598.115],[385236.909,6673599.418],[385238.873,6673600.771]]],[[[385253.336,6673323.529],[385253.196,6673327.167],[385253.434,6673336.74],[385253.842,6673340.781],[385255.05,6673348.492],[385255.264,6673351.522],[385256.187,6673362.267],[385256.601,6673368.111],[385257.101,6673374.043],[385257.351,6673379.168],[385257.874,6673384.463],[385259.047,6673391.402],[385260.214,6673396.193],[385261.019,6673398.759],[385262.212,6673402.763],[385263.278,6673405.498],[385264.37,6673407.891],[385264.773,6673408.996],[385265.016,6673410.272],[385266.822,6673416.451],[385269.345,6673427.827],[385282.433,6673474.621],[385287.092,6673488.308],[385288.761,6673493.057],[385288.995,6673493.979],[385289.616,6673495.305],[385290.366,6673496.351],[385291.351,6673497.301],[385292.302,6673497.938],[385293.145,6673498.364],[385294.362,6673498.897],[385297.62,6673500.349],[385297.98,6673500.526],[385298.251,6673500.735],[385298.517,6673501.019],[385298.704,6673501.325],[385298.834,6673501.651],[385298.903,6673501.966],[385304.621,6673540.956],[385304.757,6673545.254],[385304.665,6673547.924],[385304.407,6673550.096],[385303.478,6673555.761],[385302.608,6673558.505],[385301.505,6673561.006],[385299.789,6673563.674],[385297.889,6673566.165],[385295.527,6673568.474],[385294.062,6673569.593],[385293.527,6673570.189],[385293.082,6673570.845],[385292.703,6673571.599],[385292.491,6673572.423],[385292.408,6673573.383],[385292.782,6673576.722],[385292.799,6673577.99],[385292.744,6673579.256],[385292.615,6673580.517],[385292.414,6673581.768],[385292.141,6673583.006],[385291.797,6673584.226],[385291.384,6673585.424],[385290.902,6673586.593],[385290.14,6673588.478],[385289.51,6673590.41],[385289.014,6673592.381],[385288.656,6673594.382],[385288.436,6673596.403],[385288.355,6673598.433],[385288.415,6673600.465],[385288.615,6673602.484],[385289.025,6673605.509],[385286.869,6673630.262],[385286.818,6673631.453],[385286.873,6673632.646],[385287.033,6673633.83],[385287.297,6673634.994],[385287.663,6673636.132],[385288.127,6673637.232],[385288.688,6673638.287],[385289.339,6673639.288],[385290.359,6673640.845],[385291.243,6673642.486],[385291.984,6673644.195],[385292.579,6673645.962],[385293.022,6673647.772],[385293.309,6673649.613],[385293.44,6673651.472],[385293.414,6673653.335],[385293.392,6673654.768],[385293.493,6673656.209],[385293.716,6673657.636],[385294.06,6673659.039],[385294.521,6673660.408],[385295.097,6673661.733],[385295.784,6673663.004],[385296.575,6673664.212],[385303.906,6673674.421],[385304.853,6673675.894],[385305.643,6673677.457],[385306.269,6673679.093],[385306.722,6673680.785],[385306.999,6673682.514],[385307.097,6673684.262],[385307.014,6673686.012],[385306.751,6673687.741],[385306.374,6673690.399],[385306.324,6673693.084],[385306.601,6673695.756],[385307.203,6673698.374],[385308.119,6673700.9],[385309.336,6673703.295],[385310.835,6673705.523],[385312.596,6673707.552],[385320.255,6673715.362],[385331.245,6673726.568],[385346.056,6673739.583],[385363.211,6673751.288],[385364.818,6673774.684],[385338.618,6673767.687],[385334.419,6673766.292],[385330.416,6673764.405],[385326.667,6673762.054],[385323.226,6673759.272],[385320.142,6673756.099],[385317.459,6673752.58],[385315.215,6673748.766],[385313.442,6673744.711],[385283.115,6673662.212],[385282.728,6673661.102],[385282.377,6673659.98],[385282.065,6673658.847],[385281.789,6673657.705],[385281.552,6673656.554],[385281.353,6673655.396],[385281.193,6673654.232],[385281.071,6673653.056],[385277.106,6673607.715],[385276.855,6673605.453],[385276.496,6673603.208],[385276.032,6673600.983],[385275.463,6673598.783],[385274.791,6673596.611],[385274.016,6673594.474],[385273.141,6673592.377],[385272.168,6673590.323],[385269.877,6673586.272],[385267.204,6673582.463],[385264.176,6673578.93],[385260.819,6673575.707],[385257.166,6673572.825],[385253.251,6673570.31],[385249.111,6673568.185],[385244.785,6673566.472],[385172.82,6673541.941],[385147.49,6673525.019],[385156.59,6673526.531],[385171.382,6673528.99],[385199.48,6673533.72],[385218.993,6673545.453],[385219.181,6673544.405],[385219.337,6673543.35],[385219.461,6673542.291],[385219.552,6673541.229],[385219.612,6673540.165],[385219.638,6673539.099],[385219.632,6673538.033],[385219.594,6673536.968],[385230.975,6673538.884],[385224.425,6673542.886],[385224.35,6673543.555],[385224.264,6673544.22],[385224.167,6673544.883],[385224.059,6673545.545],[385223.939,6673546.205],[385223.809,6673546.862],[385223.668,6673547.518],[385223.515,6673548.17],[385246.974,6673562.276],[385248.639,6673563.309],[385250.274,6673564.388],[385251.878,6673565.513],[385253.451,6673566.682],[385254.99,6673567.894],[385256.494,6673569.149],[385257.963,6673570.446],[385259.395,6673571.784],[385260.772,6673571.854],[385262.152,6673571.861],[385263.53,6673571.804],[385264.904,6673571.683],[385266.271,6673571.5],[385267.628,6673571.254],[385268.972,6673570.946],[385270.301,6673570.577],[385272.235,6673569.842],[385274.049,6673568.848],[385275.708,6673567.613],[385277.183,6673566.163],[385278.443,6673564.523],[385279.466,6673562.725],[385280.232,6673560.804],[385280.726,6673558.793],[385281.415,6673554.172],[385281.878,6673549.519],[385282.113,6673544.848],[385282.121,6673540.172],[385281.901,6673535.501],[385281.454,6673530.846],[385280.781,6673526.219],[385279.883,6673521.629],[385274.811,6673498.69],[385268.995,6673500.155],[385245.124,6673408.179],[385239.054,6673384.729],[385234.167,6673278.794],[385242.727,6673277.842],[385231.81,6673162.447],[385235.404,6673162.107],[385239.859,6673172.054],[385242.908,6673177.235],[385246.074,6673180.924],[385250.571,6673185.311],[385261.113,6673194.415],[385266.27,6673198.308],[385276.707,6673204.807],[385277.619,6673205.662],[385279.295,6673207.513],[385281.675,6673210.489],[385283.484,6673213.828],[385284.805,6673219.853],[385284.989,6673226.892],[385284.59,6673230.783],[385283.867,6673234.876],[385280.739,6673245.338],[385278.904,6673250.394],[385277.567,6673253.107],[385273.812,6673259.012],[385266.057,6673268.853],[385262.519,6673273.293],[385260.262,6673276.671],[385258.45,6673280.097],[385257.021,6673283.945],[385256.069,6673287.612],[385254.84,6673295.815],[385254.164,6673309.036],[385253.336,6673323.529]]],[[[384961.858,6673683.083],[385025.91,6673592.864],[385007.596,6673707.695],[385006.31,6673708.026],[385004.995,6673708.214],[385003.667,6673708.254],[385002.343,6673708.148],[385001.039,6673707.896],[384999.771,6673707.501],[384998.554,6673706.968],[384997.403,6673706.304],[384961.858,6673683.083]]],[[[385091.033,6673895.964],[384996.594,6673881.92],[385019.461,6673737.767],[385113.843,6673752.144],[385102.018,6673826.694],[385147.44,6673833.898],[385178.45,6673791.552],[385183.385,6673773.208],[385182.533,6673759.919],[385185.842,6673759.276],[385189.098,6673758.406],[385192.287,6673757.315],[385195.393,6673756.008],[385198.402,6673754.489],[385201.3,6673752.768],[385204.072,6673750.851],[385206.706,6673748.748],[385261.248,6673710.113],[385263.758,6673708.891],[385266.484,6673708.283],[385269.276,6673708.322],[385271.983,6673709.005],[385274.459,6673710.295],[385276.57,6673712.122],[385278.202,6673714.388],[385279.265,6673716.97],[385281.088,6673725.928],[385281.371,6673730.137],[385281.545,6673731.153],[385281.917,6673732.098],[385282.472,6673732.948],[385283.188,6673733.668],[385284.034,6673734.229],[385284.977,6673734.608],[385285.976,6673734.788],[385286.991,6673734.762],[385291.954,6673734.128],[385292.631,6673734.099],[385293.303,6673734.185],[385293.951,6673734.383],[385294.556,6673734.688],[385295.101,6673735.09],[385295.57,6673735.579],[385295.95,6673736.14],[385296.23,6673736.756],[385300.785,6673749.585],[385301.222,6673750.739],[385301.706,6673751.874],[385302.235,6673752.987],[385302.811,6673754.078],[385303.43,6673755.145],[385304.093,6673756.185],[385304.798,6673757.197],[385305.544,6673758.179],[385312.536,6673766.999],[385313.55,6673768.344],[385314.499,6673769.737],[385315.379,6673771.174],[385316.19,6673772.651],[385316.928,6673774.166],[385317.592,6673775.714],[385318.182,6673777.293],[385318.694,6673778.898],[385318.926,6673779.53],[385319.242,6673780.125],[385319.634,6673780.673],[385320.096,6673781.162],[385320.62,6673781.585],[385321.196,6673781.934],[385321.813,6673782.202],[385322.461,6673782.385],[385332.714,6673784.543],[385341.237,6673787.208],[385353.712,6673789.026],[385358.375,6673788.69],[385359.297,6673788.583],[385360.221,6673788.505],[385361.148,6673788.455],[385362.075,6673788.435],[385363.003,6673788.443],[385363.93,6673788.479],[385364.856,6673788.545],[385365.779,6673788.639],[385404.498,6674351.86],[385358.69,6674572.606],[385331.526,6674663.395],[385288.629,6674650.582],[385248.281,6674639.851],[385208.916,6674628.588],[385135.09,6674602.906],[385020.179,6674559.015],[384986.2,6674544.082],[384980.687,6674541.772],[384975.193,6674539.421],[384969.716,6674537.029],[384964.257,6674534.596],[384958.816,6674532.122],[384953.394,6674529.608],[384947.991,6674527.053],[384942.607,6674524.457],[384943.115,6674520.567],[384943.128,6674516.645],[384942.645,6674512.752],[384941.675,6674508.951],[384940.232,6674505.304],[384938.34,6674501.868],[384936.029,6674498.698],[384933.336,6674495.846],[384993.398,6674211.741],[385000.397,6674211.098],[385007.228,6674209.439],[385013.743,6674206.8],[385019.802,6674203.238],[385025.276,6674198.83],[385030.048,6674193.668],[385034.014,6674187.866],[385037.09,6674181.541],[385120.455,6674172.532],[385121.253,6674172.275],[385122.014,6674171.925],[385122.729,6674171.486],[385123.385,6674170.965],[385123.975,6674170.369],[385124.489,6674169.706],[385124.921,6674168.987],[385125.263,6674168.221],[385139.608,6674102.782],[385140.806,6674097.32],[385149.878,6674041.456],[385157.38,6673995.79],[385158.081,6673990.54],[385158.465,6673985.257],[385158.53,6673979.96],[385158.276,6673974.668],[385157.704,6673969.402],[385156.816,6673964.179],[385155.616,6673959.02],[385154.107,6673953.942],[385149.935,6673943.572],[385144.482,6673933.815],[385137.836,6673924.828],[385130.104,6673916.757],[385121.411,6673909.731],[385111.897,6673903.863],[385101.716,6673899.25],[385091.033,6673895.964]],[[385305.904,6674389.631],[385321.134,6674429.029],[385329.359,6674430.592],[385337.274,6674433.325],[385344.712,6674437.169],[385351.52,6674442.044],[385357.554,6674447.848],[385362.69,6674454.462],[385366.819,6674461.745],[385369.857,6674469.548],[385372.372,6674480.42],[385372.758,6674491.573],[385371.001,6674502.593],[385367.165,6674513.073],[385361.392,6674522.624],[385353.897,6674530.892],[385344.957,6674537.571],[385334.904,6674542.412],[385260.142,6674571.313],[385249.446,6674574.326],[385238.375,6674575.279],[385227.321,6674574.139],[385216.678,6674570.946],[385206.822,6674565.813],[385198.104,6674558.923],[385190.832,6674550.521],[385185.266,6674540.902],[385182.386,6674532.999],[385180.659,6674524.765],[385180.121,6674516.37],[385180.783,6674507.984],[385182.631,6674499.777],[385185.628,6674491.916],[385189.712,6674484.561],[385194.801,6674477.863],[385179.572,6674438.465],[385305.904,6674389.631]]],[[[384975.105,6673731.008],[385007.601,6673735.959],[384985.494,6673875.324],[384927.605,6673801.744],[384934.05,6673792.148],[384975.105,6673731.008]]],[[[384918.089,6674492.245],[384915.422,6674492.378],[384912.797,6674492.867],[384910.26,6674493.701],[384907.857,6674494.865],[384905.631,6674496.34],[384903.621,6674498.097],[384901.863,6674500.107],[384900.388,6674502.334],[384891.498,6674497.256],[384882.672,6674492.065],[384873.914,6674486.762],[384865.225,6674481.347],[384856.605,6674475.821],[384848.058,6674470.185],[384839.582,6674464.44],[384831.182,6674458.587],[384833.243,6674446.82],[384836.112,6674435.223],[384839.775,6674423.852],[384844.214,6674412.76],[384849.408,6674402.002],[384855.332,6674391.628],[384861.958,6674381.688],[384869.255,6674372.228],[384870.286,6674370.892],[384871.33,6674369.567],[384872.387,6674368.251],[384873.457,6674366.946],[384874.54,6674365.651],[384875.635,6674364.367],[384876.743,6674363.094],[384877.863,6674361.832],[384878.697,6674361.032],[384879.536,6674360.237],[384880.381,6674359.448],[384881.231,6674358.664],[384882.086,6674357.886],[384882.946,6674357.114],[384883.812,6674356.348],[384884.682,6674355.587],[384885.527,6674354.941],[384886.375,6674354.302],[384887.227,6674353.668],[384888.083,6674353.039],[384888.943,6674352.415],[384889.807,6674351.797],[384890.674,6674351.184],[384891.546,6674350.576],[384892.947,6674349.884],[384894.354,6674349.205],[384895.767,6674348.538],[384897.186,6674347.884],[384898.611,6674347.243],[384900.042,6674346.615],[384901.478,6674346],[384902.92,6674345.399],[384908.627,6674343.992],[384914.41,6674342.937],[384920.246,6674342.238],[384926.115,6674341.897],[384931.993,6674341.916],[384937.859,6674342.295],[384943.691,6674343.033],[384949.466,6674344.126],[384918.089,6674492.245]]]]}}]
Try to start with a simple example and, once you got it working, extend from there 🙂
What should your geometry look like? Any donuts with holes in it?
In this example there was 6 polygons and at least one of them had holes on it.
But I will try more simple data but I have need add more complex multipolygons... hopefully it is possible.
Finally found the problem..... it was on the JS api side when I was running though array with .map.
So I changed to .flatMap() and it started to work.
Thanks your help guys.
OK - good to hear the problem is solved 🙂
