With ArcGIS Pro 2.5 release (due out this month), you can now schedule a geoprocessing tool (including ModelBuilder and Python script tools) to run at specific times and days within the geoprocessing pane! Here is a blog article elaborating more on the topic: Schedule Geoprocessing Tools and Models in ArcGIS Pro 2.5
This is very exciting news and I've been able to successfully schedule a model that performs a simple Calculate Field on a local SDE feature class in Pro 2.5, but I have not been successful trying to do the same thing with an AGOL hosted feature class. I've created a very simple model that works fine when I manually run it from the ModelBuilder interface, but which fails when it is scheduled. In the Windows Scheduler window I get a (0x1) "Last Run Result" status. Apparently when working with hosted layers it isn't as simple as it sounds. One thing that isn't clear is exactly how to specify the hosted layer - I've tried variants of the REST including with and without the token. Either way works when manually run, but neither when scheduled.
Could you provide a simple example of how to create a model that interacts with a hosted feature class? Are there any "gotchas" we need to be aware of when scheduling models that work with hosted feature classes?
#scheduled task #modelbuilder
Hi
I am getting same error In the Windows Scheduler window I get a (0x1) "Last Run Result" status.
Did you resolve this issue?
Thanks
No, I haven't solved it, sorry.
Hi Jay,
If you are using the Named User licensing model with your ArcGIS Pro, and you would like to have the scheduled tool to run without ArcGIS Pro being open, then the “Sign me in automatically” option must be selected. Let me know if this is the issue.
Jian
Thank you I do have "Sign me in automatically” selected but still getting (0x1).
Jay, thank you
Me too, still trying to figure it out
Hi Husham,
Can you send me your model or script so that I can test it here?
Thanks!
Jian Lange | Senior Product Manager (Spatial Analysis)
Esri | 380 New York Street | Redlands, CA 92373 | USA
Phone: 909-793-2853 ext. 2639| E-mail: jlange@esri.com<mailto:ichivite@esri.com>
I attached both the Model, and script converted from the same model
Thank you
Hi there,
I couldn’t see any attachments from your email. Could you please send me the files directly to my email at jlange@esri.com<mailto:jlange@esri.com>?
Husham Mohamed please try to use the full url of the feature service when scheduling, instead of a layer name. It may be that the application cannot hand over credentials for the layer to the schedule process, and we may be able to work around this by using the full url rather than the layer name.
All you need to do, instead of using the layer in the open tool dialog for your script tool prior to clicking Schedule, replace the layer name with the full feature server layer path.
This is promising. I've been trying it out today with a simple model, which is successful if I'm signed into the server, but I'm hoping to make it run when the user is not logged on. Is this possible? I keep getting results showing that the process is running, but it fails to create the output using Feature Class to Feature Class (input is an ArcOnline feature service and Output is a GDB in a folder in the same location as My Documents folder where it shouldn't have any permission issues).
Cheers. Lindsay
Hi Lindsay,
It is not possible to schedule a GP task that uses a feature service when no user is signed into the machine, at least not from the ArcGIS Pro user interface. However, you may be able to change settings in Windows Task Scheduler.
You can find the geoprocessing tools you have scheduled from within ArcGIS Pro in Windows Task Scheduler under the name of the task you specified in the Schedule window.
Hi Jian. Yes, I've found the processes created by Pro in Task Scheduler and modified it to "Run when user is not logged in" and "Run with highest privileges" but this is when it fails to happen successfully. Unfortunately it would appear that it can't be done then. This is a shame as I was hoping to replace some python scripts that create daily backups of ArcOnline data in feature services which tend to be a bit unreliable with a model in ArcGIS Pro, but if it has to be logged in, then there is still a degree of manual intervention required.
