In order to change the symbology of the map, you will need to go into the code and create a custom renderer. This requires the developer version of the source code and will require you to install a couple apps to build the code for production use.Once you have done that, you can open the MapConfig.js (source > app > javascript > playlist > config >MapConfig.js), set the use default renderer variable to false, and fill in a new renderer function in the else statement of the getRenderer function.Here's the story locator MapConfig.js file to help you out: https://github.com/ssylvia/playlist-storytelling-template-js/blob/world-of-story-maps/source/app/javascript/playlist/config/MapConfig.jsOnce you have it working, you can build your app and publish it on a server.
Hi,thanks for replying!!I downloaded the developer version and can see MapConfig.js in the path you mentioned. It doesn't let me open in notepad++ or any editor. The couple of apps to be downloaded is required for building after I edit the mapconfig right? or do I need these to edit the config file as well. Please help, I am a little lost here:(thanks!!
I went ahead and installed all the software you mentioned(phew!) I made the changes in the mapconfig file and now I am trying to build it. I get the following the "unable to read ".jshintrc" file(error code: ENOENT) .how do I fix it? please help!!thanks 🙂
Hi Julie,
I also try to use simple marker symbols for > 4 categories and downloaded the dev-version. However, I´m not sure what apps I have to install additionally? Especially I don´t find where to define the webmap-id within the source code. Any hints?
thanks & best regards
Here is the link I followed to install additional apps to setup the developer download on my machine. I could edit it and rebuild it . The link below gives good workflow. I followed it just like that and it worked for me.
Esri/playlist-storytelling-template-js · GitHub
Thank you! Well - I followed the steps but when I try to setup the project folder in the git-shell, it says "could locate Gemfile". However, I succesfully installed the gem bundler in C:\rubydev before. Any idea where I´m doing wrong?
Hi Julie, did you finally manage to change the code? I´m not sure where do adapt the MapConfig.js? Would it also be possible to modify the default renderer?
thank you & best regards
yes, I did modify so I could have 7 categories. Although I didn't change the symbols to simple ones instead I found additional number symbols . Download the additional symbols from here: http://downloads.esri.com/blogs/places/Numbered_marker_symbol_sets.zip
step 1: Once you have downloaded them move it to your playlist folder (playlist\source\resources\images\markers\indexed)
step 2: make changes to your mapconfig in the function getSymbolForDefaultRenderer(graphic,colorAttr,index)
if(graphic.attributes[colorAttr]){
if (graphic.attributes[colorAttr].toLowerCase() === "b" || graphic.attributes[colorAttr].toLowerCase() === "blue"){
iconURL = "resources/images/markers/indexed/blue/NumberIconb" + (index + 1) + ".png";
else if (graphic.attributes[colorAttr].toLowerCase() === "g" || graphic.attributes[colorAttr].toLowerCase() === "green"){
iconURL = "resources/images/markers/indexed/green/NumberIcong" + (index + 1) + ".png";
else if (graphic.attributes[colorAttr].toLowerCase() === "p" || graphic.attributes[colorAttr].toLowerCase() === "purple"){
iconURL = "resources/images/markers/indexed/purple/IconPurple" + (index + 1) + ".png";
else if (graphic.attributes[colorAttr].toLowerCase() === "m" || graphic.attributes[colorAttr].toLowerCase() === "magenta"){
iconURL = "resources/images/markers/indexed/magenta/NumbericonM" + (index + 1) + ".png";
else if (graphic.attributes[colorAttr].toLowerCase() === "o" || graphic.attributes[colorAttr].toLowerCase() === "orange"){
iconURL = "resources/images/markers/indexed/orange/NumbericonO" + (index + 1) + ".png";
else if (graphic.attributes[colorAttr].toLowerCase() === "bo" || graphic.attributes[colorAttr].toLowerCase() === "bruntorange"){
iconURL = "resources/images/markers/indexed/burnt_orange/BruntO_" + (index + 1) + ".png";
else if (graphic.attributes[colorAttr].toLowerCase() === "y" || graphic.attributes[colorAttr].toLowerCase() === "yellow"){
iconURL = "resources/images/markers/indexed/yellow/Numbericon" + (index + 1) + "Y" + ".png";
else{
iconURL = "resources/images/markers/indexed/red/NumberIcon" + (index + 1) + ".png";
Step 3: Add the additional color in your csv file.
I hope I have not missed but give it a try.
Thank you very much! However, it seems to me that just the first 4 colors in the list are respected (accordant to the max. number of the default template). Did you change something else in order to render the 7 categories you mentioned?
Kind regards
Nothing else really I did make changes in the index.html to modify the legend(see below). Did you build it to create a deploy folder or are you just previewing it? Can you send me a screen shot of the windows explorer showing the path of the addition symbols and your mapconfig file?
// Legend names for playlist markers
playlistLegend: {
// Add a name for your playlist point layer to be used in the legend.
"layerTitle": "Playlist Layer",
// Choose to display your playlist point layer in the legend (true or false).
"visible": true,
"items": {
"redIcon": {
// Choose to display icon in the legend (true or false).
// Choose the display name in the legend.
"name": "Roads & Bridges",
"iconURL": "resources/images/markers/indexed/red/NumberIcon1.png"
"blueIcon": {
"name": "Interchanges & Intersections",
"iconURL": "resources/images/markers/indexed/blue/NumberIconb1.png"
"greenIcon": {
"name": "Parks, Recreation and Culture Facilities",
"iconURL": "resources/images/markers/indexed/green/NumberIcong1.png"
"purpleIcon": {
"name": "Public Safety Facilities",
"iconURL": "resources/images/markers/indexed/purple/IconPurple1.png"
"magentaIcon": {
"name": "Transit Projects",
"iconURL": "resources/images/markers/indexed/magenta/NumbericonM1.png"
"orangeIcon": {
"name": "Sidewalks & Trails",
"iconURL": "resources/images/markers/indexed/orange/NumbericonO1.png"
"yellowIcon": {
"name": "Health & Welfare Facilities",
"iconURL": "resources/images/markers/indexed/yellow/Numbericon1Y.png"
I found out that it works when I use
iconURL = "resources/images/markers/indexed/orange/NumbericonO1.png";
instead of
Also there seem to be seem inconsistencies in the markers´ names. Some start with 1, others with 01.
Oh yes, I did rename first 10 images to fix that issue but I am glad you fixed that at your end.
Thank you again Julie - you made my week 😉
For the rest of us: if you want to activate the filter, put the name of the accordant column of your csv in the index.html here:
// Change name filter to match data
filterField: "yourcolumnname"
muchas gracias!
Wohooo...my pleasure:)
for the rest of us, the filterField is picky sometimes. It wouldn't take "Project Type" but accepted "projectType" to enable the filter.
