<layers onlythese="false">
I know this is an old forum post, but I just wanted to respond saying that I'm seeing similar results with data we are working with.
Oddly enough, we can resolve this issue by adding a field to the database table and NOT republishing the map service. After that the subtype values return just fine.
If at some point you republish the map service it starts returning bad data for the subtype field again. At that point if you remove the dummy column you added it begins to work again.
We have raised an issue with ESRI, but they claim that the IdentifyTask does not support returning subtype data and have filed this as an Enhancement Request instead of a bug. We are currently waiting to hear back from a technical person on this "enhancement request" to see if it will be resolved.
Jeff Machamer
3-GIS
Hi folks,
we have got the same problems with displaying subtype values in IdentifyTask. Can someone from Esri provide a linko to the enhancement request, so we can assure our customer, that the problem is not with our application?
Thanks.
Filip
We were provided a fix: ArcGIS 10.1 SP1 QIP for Server hot fix QFE-101SP1QIP-S-305022
There was also a 10.2 version: QFE-1022-S-299337
They listed the following in the hotfix notes as issues being addressed:
NIM097394 - The Identify tool does not display the domain and subtype description when a feature class has a join.
NIM103847 - Identify from REST returns null as the objectid for the feature from a layer that has join but no match is found for that feature in the joined table.
While none of those issues seem to be related to our issue, it did seem to fix the problem.
Hope that helps,
Jeff
Hi Jeff,
thank you for answer. I was however not able to find mentioned patches (I had a look in here, but I was not able to find the one associated with NIMs in your post).
Can you please provide me with a link or the date of issuing that patch so I am able to locate it?
Thank you very much.
