...then reference all of the feature layers ...
ESRI, it would be nice to fix this problem. Single-layer map services require two clicks in the layer list to see the symbology, something I'd prefer not to subject end-users to. It would be preferable to be able to add the individual layers and have the labeling work like it's supposed to.
Yes, the main concern is I would like the users to see the symbology in the "More/LayerList" directly without having to first expand the map service, then expand the layer
- and I would also like the users to see the labels. I have replaced the individual layers with the whole services and now the labels do render as intended.
But there is now another problem: the layers within these services are not accessible by the Attribute Table Widget. They simply do not appear in the checkbox dialog for that widget in Application Builder. Is it possible to coerce them into appearing by directly editing the widget's xml configuration file?
Or, would any of these problems be solved by using ArcGIS Server 10.1 SP1? I am now using services from a Server 10.0 SP5 install (in Flex 3.2).
