Thanks for the quick reply Brad,Unfortunately it hasn't helped my issue. I need a way to score an exact match higher than over-matches (addresses with units). See screen shot attached. I need to get the selected result (which exactly matches the searched string) to score higher than any unit address with the same root address.-chris
Chris,Did you rebuild with this style?Brad
I created a new locator from the style just to double check. It still returns the same problematic results. If it makes any difference the locator is created in an SDE 10sp2 db and I'm using Desktop 10sp2.-chris
I am trying to use BrianO's USAddresswithUnit that he posted here. However , it is doing something strange on the West pre directional. If I use W in the search it gets a score of 68 if I use West it gets 100, even though our reference data is using W. We only have West directional so I can't tell if it is the other directions too.I also created a locator with Brad's SingleHousewithUnits posted here and the W - West works fine as either gets 100% as it should. I am trying to get Brian's to work since we have fractional addresses. The xml looks the same in the Street Directions area for both, but they don't act the same.Any ideas what is wrong? I am liking the 10 locators, no more alias table to manage. Just need to get the W alias working.Thanks
Is the fraction in a separate field? It looks like there are two reasons that BrianO needed to add fractional types of addresses.1. It looks like there was a need to support house numbers like 100 A1/2 main st. Do you also require support for alpha characters in front of the fraction? If not, the style should handle addresses like 100 1/2 main st.2. It looks like the reference data that was being used had the fractional house number in a separate field as well which needed to be added to the style OR concatenation to the house number before the locator is built.
Brian,
Do you happen to have a 9.3.1 version of this?
@Patrick Corley: In response to your question regarding a 9.3.1 version--maybe? It's been so long that I don't remember what the format for those styles should be, but I have in my archive a .lot file that I believe was the "pre-version 10" style.
I am attaching it here but have no way of checking/testing to see if this is actually what you need. Please respond here with either success or failure in using the attached file, simply so others can have a status update regarding the usefulness or uselessness of the file.
Brian
I get the following message when trying to create the locator:
