ArcCatalog does allow you to add metadata to individual fields, you just need to dig in to the feature class properties.
Hi all,
Thanks you Scott for suggestion to edit field description in geodatabase. I use X-ray for ArcCatalog to do. But my geodatabase has 5 datasets and 93 feature classes. Several feature classes has the same field name. I tried to use X-ray for ArcCatalog to edit field description for each feature class. But X-ray for ArcCatalog will provide a list of unique field names for the entire Geodatabase.
My Question is : How to identify the different field description in excel spreadsheet for each feature classes.
Sukfah.
