Hi All,
See below for part of html using 3.2 javascript libraries, sample code from https://developers.arcgis.com/javascript/3/jssamples/search_suggestiontemplate.html
My featurelayer is from my ArcGIS online
var search = new Search({ sources: [{ featureLayer: new FeatureLayer("https://services1.arcgis.com/BZNs0xaSHDSi4V6G/arcgis/rest/services/postcodes/FeatureServer/0",
When I run the code, it ask to enter arcgisonline username and password. when I do this, it says incorrect username and password.
This is the same username and password, I would have used to login in directly in my ArcGIS account.
problem resolved thank you
Hi Henry,
Try replacing your service URL with the following:
https://sampleserver6.arcgisonline.com/arcgis/rest/services/SaveTheBay/FeatureServer/0
The username/password is:
user1/user1
If this passes through successfully, this will ensure you're code is correct and something is not authenticating with your service correctly.
Hi
I did change the service to
It seems to work accepted username/password.But how to I access my
("https://services1.arcgis.com/BZNs0xaSHDSi4V6G/arcgis/rest/services/postcodes/FeatureServer/0 on my ArcGIS Online?
Thanks, for your help
Can you share the service with a Group in ArcGIS Online and invite my username (jskinner_CountySandbox) to this Group? I can then see if I am able to see if I am able to access this service through the API sample.
Hi Jake,
I have sent you the invite.
Thanks
Is the layer added a CSV table? I don't see a service URL associated with the point layer in the web map you shared.
sorry check again
