Gladly. Please post back and let us know what you find.
<div id="map_layers" class="layersDiv"> <div id="map_layer0" style="position: absolute; left: 0px; top: 0px; width: 1354px; height: 521px; overflow: visible; display: block;"> <div id="map_dynamic" style="position: absolute; left: 0px; top: 0px; width: 1354px; height: 521px; overflow: visible; opacity: 1; display: block;"> <img id="map_dynamic_1321381345553" style="position: absolute; left: 0px; top: 0px; width: 1354px; height: 521px;" src="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/export?dpi=96&transparent=true&format=png8&bbox=-9181020.983518625,3176890.519266467,-9168084.016481375,3181868.480733533&bboxSR=102100&imageSR=102100&size=1354,521&f=image"> </div> <div id="map_anno" style="position: absolute; left: 0px; top: 0px; width: 1354px; height: 521px; overflow: visible; opacity: 1; display: block;"> <img id="map_anno_1321381345556" style="position: absolute; left: 0px; top: 0px; width: 1354px; height: 521px;" src="http://www.mymanatee.org/arcgis/rest/services/common-operational/streetnames-for-aerials/MapServer/export?dpi=96&transparent=true&format=png8&bbox=-9181020.983518625,3176890.519266467,-9168084.016481375,3181868.480733533&bboxSR=102100&imageSR=102100&size=1354,521&f=image"> ...<snip>...
<!doctype html> <html lang="en"> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title></title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ margin: 0; padding: 0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); var map; function init() { var initExtent = new esri.geometry.Extent({"xmin":-9177466,"ymin":3177315,"xmax":-9171639,"ymax":3181444,"spatialReference":{"wkid":102100}}); map = new esri.Map("map",{extent:initExtent}); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); var dyn = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer", { "id": "dynamic" }); map.addLayer(dyn); var anno = new esri.layers.ArcGISDynamicMapServiceLayer("http://www.mymanatee.org/arcgis/rest/services/common-operational/streetnames-for-aerials/MapServer", { "id": "anno" }); map.addLayer(anno); dojo.connect(map, 'onLoad', function() { dojo.connect(dijit.byId('map'), 'resize', map, map.resize); }); } dojo.ready(init); </script> </head> <body class="tundra"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
What are you trying to do? We would normally recommend that you stick to using public API functions to interact with your layers. What is the API missing?
<div id="map_layername"><img id="map_layername_randomnumber">/<img></div>
