"CREATED_LOCATION":"31.555114:-117.458182:12.792526:10.000000:3.000000:0.000000:-1.000000:1402525011.385171"
{ "Attributes": { "name": "Some name...", "date": "2/17/2014 15:31:45" }, "Location": "31.555114:-117.458182:12.792526:10.000000:3.000000:0.000000" }
[ { "Attributes": { "name": "Some name...", "date": 1392679905000 }, "Location": "31.555114:-117.458182:12.792526:10.000000:3.000000:0.000000", "IdxA": 9, "IdxB": 21, "Latitude": 31.555114, "Longitude": -117.458182 } ]
Hi RJ,
Will you be able to help me with creating a calculated field for the following input?
I am polling an external website for a json, here is the format of the input and the geodefinition that created by default.
I've created a flat geoevent definition but I am not sure how to map the data to the new definition and the expression in the calculated field to build the geometry.
Thank you!
Hi Sara Abasi,
the easiest way would be to use "Construct Geometry From Fields" in your input connector. This will work pretty fine if you always have the same JSON structure that contains a geometry.
Just add a new field to your geoevent definition with the Type Geometry and the Tag GEOMETRY
In the Advanced section if your input configuration you can try this:
That should work
Best,
Stefan
Thanks, I will try that.
Do you recommend creating a flat geoevent definition and using a field mapper?
Which output connector works the best? I used "Update a Feature in a Spatiotemporal Big Data Store" .
Stefan,
I used the output: "Add a Feature to a Spatiotemporal Big Data Store", count is increasing in Geoevent manger/ monitor, but there is no data when I view the feature class in portal/ content page.
First of all i would check the log-files if you find any error trying to write to the output. Maybe there is a missmatch of the geoevent defnition that has been used for publishing the service and is now used to write.
For debugging I would also suggest you to create a new output connector: Push Text to an External TCP Socket and use the GeoEvent Logger (installed with GeoEvent Server) to see what data is send to the output.
It's captured in logs for both outputs I created, Spatiotemporal and stream service:
"The GeoEvent received contains an incompatible GeoEvent Definition (Bird-Status-Changes-Created) than the schema of the destination Spatiotemporal Big Data Store Service (BirdAPI-StatusChanges-Flat)."
So you might forgot to map the GeoEvent Definition. The Definition that is received by the Ouput must match the one that has been used for publishing the service.
