Hello,
Is there a way to make the esri.dijit.Popup transparent? I tried domStyle.set(popup.domNode, "opacity", 0.1) but there is still no transparency. Thanks!
Naci,
Sure it is:
.esriPopup .contentPane { background-color: rgba(257, 247, 247, 0.75); } .esriPopup .titlePane { background-color: rgba(72, 85, 102, 0.75); } .esriPopup .actionsPane { background-color: rgba(257, 247, 247, 0.75); } .esriPopup .pointer, .esriPopup .outerPointer { background-color: rgba(257, 247, 247, 0.75); }
You can adjust the popups opacity by adding some CSS overrides but the issue is the pointer on the popup is not a real arrow/triangle it is a square rotated and when you set the opacity of the popup the pointers hidden portion of that square is now visible and look horrible.
Thank you Robert,
Could you tell what specific overrides they would be. Do you have a CSS example that produces that screenshot?
Thanks, Naci
Great! Thanks!
