I'm looking to replicate what was done in this story map:
http://townofbluffton.maps.arcgis.com/apps/MapSeries/index.html?appid=fcb6f07fbd594033a23d3289f29a72fd
Where the number on the map corresponds to the accordion item on the left.
The numbers on the map appear to behave like a point symbol and not a label but I'm unsure how to symbolize based on an attribute.
Looks like Labels. You could create the same labels in ArcMap, and then publish to ArcGIS Online.
1. Here is my point layer.
2. Enabled colored text background.
3. Changed the placement properties to place the label on top of point.
4. Changed Point Symbology to NoColor (also unchecked "Use Outline" option)
5. Here is how my point layer looks now, after enabling Labeling.
I attempted this previously but the labels will not publish to AGO. Possibly because I'm publishing as feature access and not tiled mapping?
The point layer in the above story map looks like a tiled layer though.
@JayantaPoddar Are you saying this only works with a Tiled Layer?
