I am trying to run the LAS dataset to raster tool on a Lidar data set. I receive a 99999 error along with "The specified file or folder does not exist". Any recommendations? See attached error screenshot and lidar properties screenshot.
Thanks!
Thanks for all the suggestions. I found out it was related to the originally created .lasd file not transferring over the .lasd layer statistics. I reran the Create LAS Dataset tool with 'calculate statistics' checked and it worked. Thanks again for all the help!
Can you show a screen grab of the tool inputs rather than the error message... it is too truncated to be useful.
LAS Dataset To Raster—Conversion toolbox | ArcGIS Desktop for pro... can't remember 10.3 if it was the same
Great idea! I uploaded it as an attachment to the original post.
User folder... try a different one and emulate the format of input and outputs as in the help topic I sent
'C:/data/your.lasd'
'C:/data/your_out.tif'
changing to a *.tif is now the preferred output raster format for many
It still didn't work even when I changed folder structure and output to a .tif. I am working on ArcMap 10.5.1 right now.
Hi Samiah,
Can you try turning off/turning on Background Geoprocessing? Do you still get the error?
Sometimes that does the trick!
Good luck!
-Lauren
