Hi~ Everyone,
I want to mass update existing 3,000 rows in attribute table using an excel table without deleting the geometry. Any tools or methods can do that?
Thank you
I'm guessing the problem they would face with performing a join is that it would basically add several new fields to the existing table and not necessarily solve the problem in one-shot. Though, they can always perform a Calculate Field after and copy the data over that way, after the join.
as long as you have a common field between the tables, use
Add Join....
But it would be a good idea to use
Excel to Table to bring the table into your geodatabase first
Yes, you are right. Join the table creates additional fileds, and I just want to use the existing schema for update.Because I have 3,000 rows with 20+ fields, Calculate Field can not update so many things in one-shot. I am looking for some tools in ArcGIS with that function, or some good method can achieve fast update, thank you~
Make the join permanent by saving to a new feature class, then just delete the redundant fields. Deletion is way quicker than calculating. If you need speed, you can do this externally with arcpy and numpy and/or arcpy or numpy, but I would suggest just using what you have and the tools you are familiar with, do the join, save the combined, then delete (fields) what you don't want
Sometimes it is also best just to split the data into rows to fix, rows to keep. then extract the rows you are need updating, perform the above operation, delete extra columns then append with the rows that didn't need fixing. Sometimes it is quicker to divide and recombine into a new incarnation. Often people spend too much time, trying to make changing featureclasses work for them when recreating new ones in the desired structure is often quicker
Thank you Dan, I will try this way. But it looks like no quick tool can do this...That's a pity.
Zhan, is it only one field that you are using as the linking variable between the two tables? Or is it more complicated than that?
Just an update, finally, I used field calculator to update each filed after joining the two tables. It takes long to calculate 3000+ records, but it works. Thank you for all your input~
I'm glad to hear that using field calculator essentially solved your issues!
