While not supported, the easiest way is to create empty templates of the tables inthe current database, use 'sdetable -o create_view' to build the spatial view, andthen edit the view definition to point to the other databases.If the table uses GEOMETRY/GEOGRAPHY, then just define the view yourself, andregister the result with 'sdelayer -o register'.- V
The format of the 'file=' file is documented with both 'shp2sde' and 'sde2shp', thoughit's unlikely the full range of features documented for 10.0 online were available at 9.1.You'll need to look in your local documentation for the features avaliable.Given that you are working with a view, it makes more sense to construct the view thatwill cause the least trouble at export (including limiting the column names to 10 characters).What does 'sdetable -o describe' report on your view?- V
