Hi ,
How to connect sde worksapace from wpf.Are there any examples ?
Thanks
There is not direct API for connecting to ArcSDE, however you can create Map Packages which reference layers in ArcSDE. For more information, see ArcGIS Runtime SDK for WPF
You can also create Geoprocessing packages which perform various ArcSDE data access and management functions such as listing feature classes, etc. For more information see ArcGIS Runtime SDK for WPF
Finally, you can dynamically add content from ArcSDE workspaces to the Map via the DynamicLayers capability of the LocalMapService. For more information see the following samples:
ArcGIS Runtime SDK for WPF Samples
Cheers
Mike
Hi Michel,
We are using ArcGISLocalFeatureLayer for editing feture we are adding layer in map normally and we can edit normaly in 9.3.1 SDE version from EDIT.mpk file.We are also adding layer normaly but when we trying edit in 10.1 SDE version from .mpk file RuntimeLocalServer.exe has stopped working.Here is the code below.program give exception in bold font line.
ArcGISLocalFeatureLayer sahmusFeatureLayerPoint= null;
sahmusFeatureLayerPoint= new ArcGISLocalFeatureLayer();
sahmusFeatureLayerPoint.Path = @C:\EDIT\Data\EDIT.mpk;
sahmusFeatureLayerPoint.LayerName = "POINT";
sahmusFeatureLayerPoint.Editable = true;
sahmusFeatureLayerPoint.Initialize();
sahmusFeatureLayerPoint.Initialized += (ss, ee) =>
MyMap.Layers.Add(sahmusFeatureLayerPoint);
private void okButton_Click(object sender, RoutedEventArgs e)
if (comboFeature.SelectedIndex != 0)
ESRI.ArcGIS.Client.Graphic addGraphic = new Graphic();
addGraphic.Attributes.Add("TYPE", comboFeature.SelectedIndex);
addGraphic.Attributes.Add("DESCRİPTİON", txtAciklama.Text);
addGraphic.Attributes.Add("USER", txtKullaniciAdi.Text);
addGraphic.Geometry = m_EditReelPoint;
sahmusFeatureLayerPoint.Graphics.Add(addGraphic);
sahmusFeatureLayerPoint.SaveEdits();
sahmusFeatureLayerPoint.Refresh();
Here is also exception output:
View problem details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: RuntimeLocalServer.exe
Application Version: 10.2.0.3607
Application Timestamp: 525c3f91
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.18798
Fault Module Timestamp: 5507b485
Exception Code: ebf00baa
Exception Offset: 0000c42d
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1055
Additional Information 1: 1145
Additional Information 2: 1145d54f633f55d317cd2ab4c6541b42
Additional Information 3: 1f67
Additional Information 4: 1f6755aae98366e0489b81cde6820b48
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\windows\system32\en-US\erofflps.txt
Which version of the ArcGIS Runtime SDK for WPF are you using?
Please can you describe your scenario/workflow?
-We are using 10.2.0 version of the ArcGIS Runtime SDK for WPF.
-We want to create ArcGISLocalFeatureLayer and we want to create or edit features in ArcGISLocalFeatureLayer.After adding feature ArcGISLocalFeatureLayer crash dialog that as you can see in previous message.Application works fine edits feature in 9.3.1 version of SDE but in 10.1 version of SDE don't edit.Is it about licence problem 10.2.0 version of the ArcGIS Runtime SDK for WPF.
Thanks.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
