I there a setting that I need to change to include the bookmarks?
Hi Matt,Thanks for your pointer, after switching off Street Network layer the model successfully exported. But now I need to figure out whats the problem in the shape geometry.Thanks.
Hi Carlno setting required, this should work out of the box.Can you try the following:in the problematic scene* create a new shape layer "test" with a single shape* hide all other layers* start 3ws exporter, and set exported content to "export shapes only"* exclude all layers from being exported (uncheck in second export page) except "test"* does the problem still occur?* if so, can you post the problematic 3ws here so we can track the problem down?
25188ms: Reading: 98% (57.25 of 58.51 MB).
I'm having the same problem with the Web Scene that I have just created. And upon checking, all the web scenes that I have created before no longer loads properly in the web viewer.
How do I resolve this issue? My browser is updated, as well as my graphics drivers. Thanks!
Marian Marigmen
11ms: CE Web Viewer version: 3.10 [ 3.10.0.201511160532 | html:3.10.0.201511160532_ ]
28ms: GL detect: WebGL 1.0 (OpenGL ES 2.0 Chromium) More
SHADING_LANGUAGE_VERSION: WebGL GLSL ES 1.0 (OpenGL ES GLSL ES 1.0 Chromium)VENDOR: WebKitRENDERER: WebKit WebGLEXTENSIONS: ANGLE_instanced_arrays, EXT_blend_minmax, EXT_frag_depth, EXT_shader_texture_lod, EXT_sRGB, EXT_texture_filter_anisotropic, WEBKIT_EXT_texture_filter_anisotropic, OES_element_index_uint, OES_standard_derivatives, OES_texture_float, OES_texture_float_linear, OES_texture_half_float, OES_texture_half_float_linear, OES_vertex_array_object, WEBGL_compressed_texture_s3tc, WEBKIT_WEBGL_compressed_texture_s3tc, WEBGL_debug_renderer_info, WEBGL_debug_shaders, WEBGL_depth_texture, WEBKIT_WEBGL_depth_texture, WEBGL_draw_buffers, WEBGL_lose_context, WEBKIT_WEBGL_lose_contextMAX_TEXTURE_SIZE: 16384MAX_RENDERBUFFER_SIZE: 16384MAX_VERTEX_TEXTURE_IMAGE_UNITS: 16
562ms: Loading webscene id : eae2aa5ca6224631947cc9c5550b0262
569ms: Fallback to custom unzip on arraybuffer and custom streamParser
6613ms: Unable to load data : http://www.arcgis.com/sharing/rest/content/items/eae2aa5ca6224631947cc9c5550b0262/data
6613ms: Unable to load URL Error status 0 on http://www.arcgis.com/sharing/rest/content/items/eae2aa5ca6224631947cc9c5550b0262/data
6618ms: Downloading: 0% (0 of 11.16 MB)
I tried to download your data, and view through offline viewer,
here is the log :
29150ms: Loading scene file : Bonifacio_Final.3ws
29752ms: Using custom unzip and streamparser on arraybuffer
31197ms: Reading: 76% (16.63 of 22 MB)
31266ms: Invalid Web Scene (3ws) data clarinet parser error in Bonifacio_Final.3ws: Error: Max buffer length exceeded: textNode Line: 1 Column: 883400 Char:
seems your data is not valid or corrupted.
Hi, khairul amri.
I can't also load the web scenes which I was able to do so before.
Details
Downloading: 0% (0 of 18.84 MB)
29ms: GL detect: WebGL 1.0 (OpenGL ES 2.0 Chromium) More
425ms: Loading webscene id : d3177637843e4fd39517540834befd76
433ms: Fallback to custom unzip on arraybuffer and custom streamParser
6394ms: Unable to load data : http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/d3177637843e4fd39517540834befd76/data
6395ms: Unable to load URL Error status 0 on http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/d3177637843e4fd39517540834befd76/data
6401ms: Downloading: 0% (0 of 18.84 MB)
Here's another one:
597ms: Loading webscene id : 97c5ee191b8e43ceb1b700309962e608
608ms: Fallback to custom unzip on arraybuffer and custom streamParser
6163ms: Unable to load data : http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/97c5ee191b8e43ceb1b700309962e608/data
6163ms: Unable to load URL Error status 0 on http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/97c5ee191b8e43ceb1b700309962e608/data
6169ms: Downloading: 0% (0 of 8.54 MB)
CityEngine Web Viewer Help
I was able to properly open these web scenes just a few weeks back. What could be the reason(s) that they are not loading now? Thanks!
