How do you add a date field to the Job Query Results - List View window in WFM?
Hi Jake,
If you try to include a date field that is available from the Workflow Manager schema table into the query result, you can configure the job query in Workflow Manager Administrator - right click on the job query to Define Job Query - Fields tab. Add the date field from the left side tree view to the right.
If you have switched the Define Job Query into SQL view, you will need to include the date field in the SQL statement of query.
Hope this help.
Meggie
